No Sound After Reboots
Everytime I reboot my phone I have to manually go into the sound settings and switch the output sound setting from Default to Phone and then back to Default or my speakers don’t work. Anyone have a fix for this? Began happening after using headphones to listen to podcasts
(09-22-2020, 06:32 PM)LMalilil Wrote: Everytime I reboot my phone I have to manually go into the sound settings and switch the output sound setting from Default to Phone and then back to Default or my speakers don’t work. Anyone have a fix for this? Began happening after using headphones to listen to podcasts
Same happened to me recently. If I set the output to internal speakers sometimes it stays and sometimes it reverts to headphones (which I do not have nor have ever plugged in). When audio is set to headphones I can neither hear callers, nor they me.
I do not know how to correct it, apart from setting it to internal and checking regularly that it has not reset to headphones. Not sure that it is a pinephone only problem - my pinebook pro audio was set to 'dummy output' yesterday too
  Sound : notifications freelectro 6 1,744 06-07-2023, 01:03 AM
Last Post: freelectro
Exclamation No sound anonymous 22 8,476 11-08-2022, 09:07 AM
Last Post: dante404
  Time is wrong after reboots stucked at 27th august user641 2 1,220 09-08-2022, 01:39 PM
Last Post: user641
  spontaneous reboots in jumpdrive mode flynx 0 600 08-23-2022, 03:48 PM
Last Post: flynx
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 2,618 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 1,036 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 3,219 12-27-2021, 05:40 AM
Last Post: Anna
Bug Sound defaults to Headset User 18618 10 8,639 10-21-2020, 06:06 PM
Last Post: ThrillGates
  earpiece sound setting Gobelin 3 3,249 08-13-2020, 01:46 PM
Last Post: Gobelin
