Let's talk about safety of Pinephone
#31
(10-08-2020, 05:23 PM)Alho Wrote:
(10-08-2020, 09:05 AM)wibble Wrote: Given that 'this problem' is actually several problems there is no single solution. This is a potential long term solution to problem part 4 that Megous identified - the limit on battery discharge rate being lower than the potential power consumption of the device. While it mostly talks about power usage in terms of its relation to temperature, it is equally applicable to how much is being drawn from the power supply.
There is no overheating problem here at all. According to the conventional performance tests of the battery,
the battery can be discharged with a 1C load - and should last at least 54 mins.
I doubt that we can easily put an 1C load to the battery (2.8A) in the phone.
The same performance tests also indicate that the battery can be charged with 1C
which should give it a full charge (0-100% in less than 2.5 hours.
That said, using 1C may wear the battery down faster than using the usual 0.5C
but there is no safety risk involved.
Reference please - it's good news if true, but the datasheet specifies 0.5C for maximum sustained charge and discharge current. Perhaps they're being overly conservative, but I'd like to see some good evidence before declaring it safe to operate at double that.
https://wiki.pine64.org/images/0/04/Pine...2-2750.pdf
You simply have to read the right spec file :-)
Your linked one is for the v1.0 dev phone
The batteries for 1.1 BH and up is here:
http://files.pine64.org/doc/datasheet/pi...cation.pdf
Read §5.1 Conventional performance
Good find
Thanks - link in the wiki Battery section corrected so nobody else makes the same mistake ;-)
Doesn't the Lithium Ion battery itself have some physical circuitry that protects things like shortcuts, over-charges and heats up and expands the battery, irrespective of software, and catches fire?
Yes, it does have such a safety circuit. It is described in the spec sheet.
  pinephone virtual keyboard aular 4 303 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 200 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 474 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 108,184 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,722 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 576 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,262 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 477 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,638 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,859 12-04-2023, 02:14 AM
Last Post: Peter Gamma
