09-16-2020, 04:39 PM
While I'm familiar with Linux (I've been using it since 1993), I'm not familiar with Linux on the PinePhone. How do I know if the PinePhone can see my SD card?
SD Card
09-16-2020, 04:53 PM
df -h
will list all mounted filesystems. if it's not listed in there then it's not mounted by the system
09-17-2020, 10:43 AM
Enter blkid on commandline prompt and you will get some more information. However you will need some imagination to find out which entry might be the SD-Card.
09-18-2020, 04:43 PM
(09-17-2020, 10:43 AM)LinAdmin2 Wrote: Enter blkid on commandline prompt and you will get some more information. However you will need some imagination to find out which entry might be the SD-Card. I figured out which one was the SD card, and installed Mobian. On only a slightly different front, I was THRILLED to discover that OpenJDK was apt-get'able on Mobian. I wrote a very simple test Java Swing program, and it worked. I haven't figured out how to put a launcher icon on the phone's desktop, though.
09-20-2020, 08:43 AM
(09-18-2020, 04:43 PM)AppDeveloper Wrote: On only a slightly different front, I was THRILLED to discover that OpenJDK was apt-get'able on Mobian. I wrote a very simple test Java Swing program, and it worked. I haven't figured out how to put a launcher icon on the phone's desktop, though.https://developer.gnome.org/integration-...es.html.en |
install iso from sd card to emmc | aular | 2 | 316 |
03-11-2024, 10:24 PM Last Post: tllim |
How To Access the Pine Phone Auxillary microSD Without Removing Card | pinephoneuser22 | 2 | 932 |
01-09-2024, 07:02 PM Last Post: britelite |
SD Card has wrong capacity | AndyM | 11 | 2,335 |
06-11-2023, 12:30 AM Last Post: AndyM |
Device Unable To Read MicroSD Card | _radv_ | 19 | 6,089 |
02-18-2023, 02:01 PM Last Post: _radv_ |
SIM Card Slot Terror | thismarty | 4 | 1,465 |
12-21-2022, 05:37 PM Last Post: thismarty |
MicroSD Card Reuse | _radv_ | 5 | 2,002 |
12-12-2022, 12:26 PM Last Post: chainingsolid |
Pine Phone Doesn't Recognize New MicroSD Card | _radv_ | 3 | 1,411 |
11-23-2022, 05:19 AM Last Post: _radv_ |
SIM Card Install | pineme | 4 | 5,115 |
06-10-2022, 03:15 AM Last Post: rocket2nfinity |
SIM card slot not working | dekrets | 2 | 2,192 |
02-12-2022, 11:09 AM Last Post: dekrets |
I just got to find phone in my sd card won't read | Tyro | 5 | 5,983 |
11-15-2021, 01:11 AM Last Post: alexenwaston |
