Can we dualboot eMMC and SSD
Hi guys.
Recently I got my Pinebook Pro and M.2 adapter.
And here is my question is it possible to dual/triple boot?
Like Manjaro installed on eMMC, Kail Linux installed on SSD and SD Card for Elementry OS (or other distros for testing) .
As far I know Pinebook not have BIOS and bootorder is SD Card > eMMC > SSD
Would be happy to have something like GRUB so I could switch OS on power up Smile
Thank you
Over time it will likely be possible to multi-boot different OSes, even on the same storage device.
There is an experimental U-Boot with 2 separate menus. One for device selection, like eMMC or SD card. The other for kernel or partition. It's not quite as easy to use as Grub. And their are limitations. Here is the thread discussing it;
https://forum.pine64.org/showthread.php?tid=10694
I have it on one of my Pinebook Pros, seems nice. Can even be written to SPI.
Arwen Evenstar
Princess of Rivendale
(09-15-2020, 04:52 AM)Arwen Wrote: Over time it will likely be possible to multi-boot different OSes, even on the same storage device.
Is there any guide for setup U-Boot? I'm not scared of terminal Big Grin xd
@Madiator2011, As for a guide setting up U-Boot, I don't think so.
Most, (if not all?), SPI flash versions of U-Boot are a single binary file that gets flashed to the SPI device. But, for eMMC and SD card, their are 3 separate pieces of U-Boot;
Offset      End     Size   Type
    64    16383    16320   idbloader.img
  16384    24575     8192   u-boot.img
  24576    32767     8192   trust.img
Arwen Evenstar
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 59,892 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,475 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,232 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,692 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,144 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 1,999 01-17-2023, 12:07 PM
Last Post: nfms
  What OS have you recently flashed onto PBP eMMC? jcun4128 6 2,350 11-26-2022, 09:39 AM
  Unable to boot from emmc after flashing it rfm83 3 1,765 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,041 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,346 09-28-2022, 06:22 PM
