My PineBookPro Dead
Hi , I have a big problem . And I wanna say I'm noob in Linux
Well , my laptop probably dead it has only black screen when I turn it ON .
In last session I ran some command in terminal and notebook going dead .
There is some command after it dead :
fdisk /dev/mmcblk2
and in fdisk menu i press d (i think it delete)
and then I reboot laptop and it just dead (Black Screen)
[Moderator note: Removed image that was not displaying properly.]
I also tried to boot it from SD cart but it just blinkin' red and same black screen
In my opinion I just erase all software in laptop
Please help me reanimate my PinePro.
Hope for your help guys
please host your images somewhere like imgur.com, these boards don't handle attached images well and we can't see what you shared.
you may have nuked your install. no worries, you can grab nearly any image from the Software Release wiki page for the PBP, flash it to your eMMC, and be back in action.
(09-14-2020, 05:52 AM)voodooman Wrote: Hi , I have a big problem . And I wanna say I'm noob in Linux
fdisk /dev/mmcblk2
Hi voodooman
I had a similar issue the day before yesterday.
I'd try re-flashing an SD-Card with the "default" manjaro KDE found at wiki.pine64.org
And then either use the manjaro arm flasher or dd command to copy to eMMC.
I myself had to screw open my Pinebook Pro to press the reset button, but mine was not even blinking any LEDs when trying to turn on.
Kind regards
Tharadash
  Dead new PBP? Jam3s007 5 1,195 09-29-2023, 02:47 PM
  Dead Pinebook Pro Keyboard Keys calinb 2 1,052 09-02-2023, 12:31 PM
Last Post: calinb
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,234 06-11-2023, 07:59 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,760 01-22-2023, 10:05 PM
Last Post: rfm83
  PinebookPro CPU Speed setting therosery 0 680 09-07-2022, 05:02 AM
Last Post: therosery
  PinebookPro Build Errors mexsudo 3 2,919 01-30-2022, 08:36 AM
Last Post: mexsudo
  Need Advice for Wiping eMMC on Dead LCD Pinebook Pro calinb 9 8,270 05-10-2021, 12:49 PM
Last Post: calinb
  Virtualization on the PinebookPro astr0baby 25 29,404 04-27-2021, 09:02 AM
Last Post: moonwalkers
Exclamation Pinebook Pro dead after dd crmcalls 2 2,833 03-03-2021, 07:57 PM
Last Post: globaltree
  PineBookPro does not charging floppy_rofling 0 1,649 02-03-2021, 05:29 AM
Last Post: floppy_rofling
