Selling the PinePhone on Aliexpress?
I live in Switzerland and often buy products directly in China from Aliexpress.com. They have an excellent store, and shipping via Aliexpress standard shipping is cheap, I guess around 10 USD for a 150 USD device. Shipping time over Aliexpress standard shipping is about two week and reliable. You can send products also through China Post, which is even cheaper, but takes more than a month. When the PinePhone is produced in China or Asia, why not to choose Asias best store with Asias best shipping method?
Here is an example of an Aliexpress seller. He solved a problem I had for a long time, namely to connect an EEG sensor to a phone or PC. He solved it by adding a Bluetooth module. I m very happy about this product. It offers many connection software possibilities which where not available before, for instance by using BlueSoleil.
469 pieces are currently available on Aliexpress. The only limitation is that he only sells a maximum of 5 pieces per customer. I hope this limitation will also be overcome soon, since I need more than 5 pieces:
https://de.aliexpress.com/item/326063189...hweb201603
Can the PinePhone also be sold in the way of this example?
  pinephone virtual keyboard aular 4 304 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 200 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 474 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 108,193 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,722 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 576 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,262 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 477 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,639 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,859 12-04-2023, 02:14 AM
Last Post: Peter Gamma
