No consistency in where PP boots from
I have UT on my eMMC and multiple distros on different SD cards including a newer UT so i can use it with expanded memory. For some reason, regardless of what SD card i put in, about 40% of the time it will bpot from eMMC and the other 60% it boots feom the intended SD card. My understanding is it should only boot from SD if one is present, but thats not my experience. Sort of like flipping a coin each time i boot.
Starting to wonder if this is an issue with the sd slot and sd card having a loose fit. But very likely an issue with the previous state of a flip flop in an IC when shutting down.
  Article: PinePhone boots Apache NuttX RTOS lupyuen 0 827 08-27-2022, 05:31 AM
Last Post: lupyuen
