Phosh still in English, after switching languages
... Are there localisation packages I have to install to get the interface localized, or how to I achieve full localisation?
Thanks!
Johannes
(09-09-2020, 12:28 PM)jro Wrote: ... Are there localisation packages I have to install to get the interface localized, or how to I achieve full localisation?
Thanks!
Johannes
From the forum:
small note: is something wrong with the location?
I change the following for each img:
locale -a
C
POSIX
localectl
  System Locale: LANG=de_DE.UTF-8
      VC Keymap: n/a
      X11 Layout: n/a
localectl set-keymap de
localectl set-x11-keymap de
sudo nano /etc/locale.gen
#de_CH ISO-8859-1
de_DE.UTF-8 UTF-8
#de_DE ISO-8859-1
sudo locale-gen
sudo nano /etc/locale.conf
LANG=de_DE.utf8
LC_CTYPE="de_DE.utf8"
LC_NUMERIC=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
LC_COLLATE="de_DE.utf8"
LC_MONETARY=de_DE.UTF-8
LC_MESSAGES="de_DE.utf8"
LC_PAPER=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
LC_ALL=
Then everything can be changed to my language in Region & Language settings
locale -a
C
de_DE.utf8
POSIX
It depends on your language.
For example, I had to change to Mobian because Manjaro doesn't include a Japanese locale for some reason.
But if your language is available, once the language is set, a reboot will be required.
Chances are that the language is lacking translation in some areas.
Like here for example, where on one hand you can see パスコードを入力(input passcode), but on the other hand you see Unlock instead of 解除 (unlock in the sense of "remove restriction") or 確認 (verify).
[Image: 20201201_09h21m44s_grim.png]
Or some specific areas of the settings screen like "Mobile", which is entirely in English at the moment.
Or the chat app that is literally half translated.
I can translate them and I'm willing to do so, but I don't really understand how to submit my POT file.
There is definitely something wrong with how Manjaro handles locale, the post that firefox-58 mirrored here is a(n ugly) workaround, here's the bug report with a (IMO) better solution. The issue boils down to no matter what $LANG you set in /etc/locale.conf, it always defaults to C.UTF-8.
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 718 04-25-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 809 02-24-2023, 12:56 PM
Last Post: jakfish
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,010 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,400 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 1,811 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Phosh Issues Csanderson0313 7 5,736 03-05-2022, 08:23 AM
Last Post: Csanderson0313
  No wifi with phosh image wave22 3 2,340 02-15-2022, 07:25 AM
Last Post: wave22
  How to remove Manjaro Phosh lock screen password? Avisando 4 3,780 10-28-2021, 04:20 AM
Last Post: Avisando
  How can I update Manjaro ARM w/ Phosh using Terminal? danimations 6 3,880 10-24-2021, 11:58 PM
  [phosh] boost pipewire volume beyond 100%? dcinoz 3 3,681 10-16-2021, 02:41 AM
Last Post: lacriz
