Fading screen from 2020 9 8 nightly image
After a week of absence i came back and flashef the 9 8 image onto my pinephone ubport CE. At night all seemed fine. The mobile network still drops out and need a.reboot to wakeup . Being out in broad daylight though i was having problem (i enabled auto screen adjustment) i was having the screen gradually fade on me even when i was typing or trying to navigate the screen. It was a.bit comical as i could never select fast enough to get to the Settings to disable the auto function.
(09-09-2020, 10:45 AM)HLing Wrote: After a week of absence i came back and flashef the 9 8 image onto my pinephone ubport CE. At night all seemed fine. The mobile network still drops out and need a.reboot to wakeup . Being out in broad daylight though  i was having problem (i enabled auto screen adjustment)  i was having the screen gradually  fade on me even when i was typing or trying to navigate the screen. It was a.bit comical as i could never select fast enough to get to the Settings to disable the auto function.
I’m not sure if this is related to your problem, but my Pinephone (with pmOS) also suffers from a similar problem.  The screen dims whenever you accidentally cover the proximity sensor, even when you’re not in a call.  Can you turn covering up your proximity sensor with a finger or something?  It’s located at the left of the speaker grills and camera.
(I put away the phone for the day.  At night, I turn it on again. All was fine. I still made sure to undo the auto brightness just in case. )  I'm not sure I understand where the proximity sensor is? And do you mean that it will dim for when you put it to the ear to talk on the phone?
  cant verify mobian image at website gnugpg penguins_rule 0 117 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Screen auto-rotation sensitivity mdk 0 264 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 643 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,074 06-22-2023, 11:20 AM
Last Post: Melechtna
  Most recent Mobian image or installer image known to work? DrPlamsa 13 4,850 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  Lock screen question: always squeekboard tuxcall 1 1,205 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,004 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,494 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,767 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,228 07-18-2022, 03:29 AM
Last Post: vusra
