What OS is working?
What operating system is currently the best, meaning what OS has the most features working and more stable? I need to get my PinePhone operational to replace my Samsung S3.
Thanks in advance.
(09-09-2020, 09:26 AM)K_Research Wrote: What operating system is currently the best, meaning what OS has the most features working and more stable? I need to get my PinePhone operational to replace my Samsung S3.
Thanks in advance.
I've personally had the most luck with Mobian on my PinePhone - am currently running a custom build of it (using X and LXDE rather than Wayland and Phosh) as my daily driver. It's not perfect, but it's getting pretty heckin' close in my opinion.
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
Thanks for the reply can you give me a link to the file your using I would like to try the same
Second the vote for Mobian. It's the smoothest and most stable release I've tried. All of the basic functions on PMOS and UBports also work, but they're not as stable as Mobian on my 3GB/32GB phone.
(09-09-2020, 10:34 AM)K_Research Wrote: Thanks for the reply can you give me a link to the file your using I would like to try the same
I built my image using scripts from https://gitlab.com/rrico542/mobian-x-recipes/ but your best bet is probably to start with the latest image from https://images.mobian-project.org/pinephone/nightly/ and give that a spin before you dive into a custom build.
There's more info on the project wiki at https://wiki.mobian-project.org/ and an active sub-forum here at https://forum.pine64.org/forumdisplay.php?fid=139
Thanks in advance.
Thanks for the info, I downloaded mobian-pinephone-20200911.img installed to a 32GB SD card, booted, camera works! Notified of a OS update, installed the update and it rebooted, still have to check out other stuff if ok I will install the card from my old phone and see if I can make receive calls.
From what I have seen its way ahead of the Ubports
Again thanks
FYI, I don't think any distro has MMS functionality yet.
Thanks in advance.
Mobian works from the download "out of the box" pretty well, ya do need the correct settings,,,
 the camera works but not great yet, most of the on screen apps work.
PMOS as per the factory install works talk, text, data, but not many features.
Manjaro works, but I have not used it much yet.
UBPorts, seems to work for some people.....
That just my view,  Probably best to check the threads in the forum to investigate the many distro's
As I am sure some others are also working, some of them are doing fairly well...
One thing that I have not seen yet is no one appears to have MMS working   ...   yet.
What service ? I have T-Mobile and everyone's like, "Ummm, yeah I hear you but not clear." Either that's true with T-Mobile or I have way to many complainers in my life.
(09-13-2020, 08:46 PM)NobodyNew1 Wrote: What service ? I have T-Mobile and everyone's like, "Ummm, yeah I hear you but not clear." Either that's true with T-Mobile or I have way to many complainers in my life.
Which operating system are you using ?
I have 2 PMOS 3g ram phones,
One is still post market OS operating system on ATT  (factory installed OS)
One is Mobian on T-Mobile  (nightly build sept. 14 )
I think the Mobian sounds better, but I do not think the carrier matters in this case.
But both do 'work'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,823 03-09-2024, 11:38 PM
Last Post: dcinoz
  MMS sending stopped working amindfv 2 1,238 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,363 10-08-2022, 04:45 PM
  JumpDrive isn't working phytocube 2 1,781 06-05-2022, 03:22 PM
Last Post: phytocube
  SIM card slot not working dekrets 2 2,202 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 2,927 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 9,102 01-19-2022, 02:08 AM
Last Post: bcnaz
  Video Out not working BenniTec 7 5,176 10-21-2021, 11:56 AM
Last Post: BenniTec
  How did you get data working on PureTalk? nelstomlinson 2 2,895 09-26-2021, 03:50 PM
Last Post: nelstomlinson
  JumpDrive not working due to device busy cnxsoft 3 3,062 08-08-2021, 12:18 AM
Last Post: mouffa
