Status update 2020-09-05
#21
(09-22-2020, 02:41 PM)dukla2000 Wrote: "...Have also got apt's knickers in a knot with python3-yoyo etc trying to get all the upgrades in: managed to muscle the 5.8 kernel through. But in any event realise this has nothing to do with F2FS..."
Is this the message you got? "..trying to overwrite '/usr/lib/puthon3/dist-packages/yoyo/_init_.py', which is also in package python3-yoyo-migrations 7.0.1-1....."
What does one do at this point?
#22
I am not sure if dpkg is installed by default. I vaguely remember having installed it manually. Anyway use remove instead of purge if you use authenticator.
dpkg --purge python3-yoyo-migrations gnome-authenticator
apt full-upgrade
apt install gnome-authenticator
#23
Yup
(09-23-2020, 08:45 AM)fernando_c_m Wrote: ...
apt full-upgrade
Thanks - worked like a charm
#24
Yup
apt full-upgrade
I hadn't been using Authenticator even though I got the error message?
#25
(09-05-2020, 09:08 AM)a-wai Wrote: ...
We also have an experimental build using F2FS for the root filesystem, available here,
Have only been using the F2FS version the last couple of days, including a clean restart with the 20200921 version yesterday. So not sure if my problem is related to the F2FS version, but I can no longer slide sideways through the open applications in phosh. If I shrink the current application then I can only select either its neighbour on the left or right - I can't slide sideways to see all the open applications.
BTW should add that crashes seem a bit reduced now. Still running from SDcard, logfile still full of "mmc_erase: group start error -110, status 0x0". But my generic USB-C dongle (one from fleabay, not the CE Pine edition one) working fine to provide at least a working RJ45 Ethernet connection.
#26
(09-25-2020, 03:24 AM)dukla2000 Wrote: ... I can no longer slide sideways through the open applications in phosh. If I shrink the current application then I can only select either its neighbour on the left or right - I can't slide sideways to see all the open applications.
Fixed by yesterday's updates - thank you to all concerned.
Also a fix so that clicking on a link (in say an email) opens a new tab in Firefox - till now always bombed if Firefox was already open. Again thanks to those toiling away.
#27
We also have an experimental build using F2FS for the root filesystem, available here, which improves the system's responsiveness and seems to perform quite well overall.
Sorry - have given up working with F2FS for now as have had a really unstable week, not sure the cause(s) of course. But my biggest gripe (apart from cluttering the log file - I was always running from an SDcard) is about every 7 days I had an extraordinarily long boot - like 3-5 minutes. I suspect this was an fsck on / but never trapped a log to be sure. Again not sure if routine maintenance of F2FS is slower or my SDcard (Evo+ 32Gb) was the cause?
  Mobian repository status henrythemouse 16 8,736 04-10-2024, 10:02 AM
Last Post: diederik
  how to update mobian over tor vusra 13 6,883 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,227 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,333 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,211 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,297 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 5,306 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,857 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 4,741 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 5,075 08-22-2022, 12:19 PM
