USB-C Power Delivery
I just flashed 4 September 2020 nightly build onto my Braveheart.
USB-C PD (Power Delivery) doesn't seem to work any more with *my* charger. It used to work when I was using an older image (which also ran kernel image 5.6 not 5.7).
I don't have a second PD charger to test.
Can someone please confirm that their PD charger works on a recent nightly build? If it does, please let me know the date of the nightly build you used. Please also tell me what make/model of PD charger you used.
I'd like to check this with others before I investigate further the cause.
Thanks Smile
EDIT 2020-09-06
Solution is to blacklist anx7688
Credit goes to https://forum.pine64.org/showthread.php?tid=11198 and https://wiki.mobian-project.org/doku.php?id=tweaks
(09-05-2020, 01:51 AM)cmicallef Wrote: Hello,
Thanks Smile
EDIT 2020-09-06
Glad you found the solution. When that happened to me I didn't find the answer until my phone had died so the only way to charge it was removing the SD card and charging it without Mobian in.
Doesn't blacklisting ANX7688 disable video output over USB-C to HDMI?
(09-05-2020, 09:10 AM)lot378 Wrote: Doesn't blacklisting ANX7688 disable video output over USB-C to HDMI?
It is currently not enabled in mobian anyway Smile
Sad
i'm not able to make PD type-c charging work with that kernel module and without it on recent versions of Mobian and Ubuntu Touch. Sad
I tried different PD chargers, PD type-c cables. No success.
Guys, are you sure PD charging works on your phones? what is the indication of it? how do you know PD works?
I've not been able to get PD charging to work either, but I got BC1.1 (7.5 W) charging to work using this tweak.
I am not fully convinced that it is a good and safe idea to blacklist the anx7688 module.
https://xnux.eu/devices/feature/anx7688.html
(10-02-2020, 07:33 AM)LinAdmin2 Wrote: I am not fully convinced that it is a good and safe idea to blacklist the anx7688 module.
@LinAdmin2 could you please give your reason/s why you do not think it is a good and/or safe idea?
Thanks Smile
EDIT 2020-09-06
The blacklist anx7688 has saved me so many times, but there's also another thing to watch out for (I'm sorry I can't remember who alerted me to this): That you should try disconnect your charger while rebooting. There has been times when that worked without me having to issue the blacklist anx7688.
  Power Consumption on Suspend JudgeFudge 8 1,828 07-29-2023, 06:24 AM
Last Post: JudgeFudge
  Screen stay black unless power key pressed short freelectro 0 643 06-24-2023, 01:55 PM
Last Post: freelectro
  Notification light when entering low power Barugon 5 3,458 11-22-2021, 06:20 AM
Last Post: beta-user
  Manjaro convergence edition (3GB) charging/power issue Saliency 1 2,389 11-24-2020, 11:04 AM
Last Post: Saliency
  USB-C Power Delivery does not work nazarii.kretovych 2 3,568 10-05-2020, 09:15 AM
Last Post: wibble
  Delayed shut down or restart through power menu DarkManiels 1 2,529 10-04-2020, 07:19 PM
Last Post: HLing
  CRUST power management on Mobian 0x070 6 8,701 07-16-2020, 04:30 AM
Last Post: a-wai
  power management change? pjsf 1 3,399 06-05-2020, 05:16 PM
Last Post: a-wai
