call audio
#21
Definitely sounds like software given you have tested every possible scenario and the results are all over and not predictable.
Possible an issue with pulse/alsa and hot plug detection.
Very weird.
#22
(09-09-2020, 05:09 AM)SwordfishII Wrote: Definitely sounds like software given you have tested every possible scenario and the results are all over and not predictable.
Very weird.
Brain hurts. Very strange behavior that mine is doing. I think I will reimage the phone and go from there, atleast then I can be sure then what's running on it.
A definite win that it's making calls now.  Should probably just accept that it seems to be working right at this moment and be thankful enough for that ;-)  Maybe this discussion will help some with a similar issue in future..
TLDR:
Plug unplug the headphone lots of times, switch your UART on/off a bunch of times.. reboot, update, reboot, repeat. It'll probably work.  ;-D
#23
OK, so just to update future readers of the thread..  I had an up to date PMOS on my handset until today still with call audio issues (low volume, robot voice, cant understand - all sporadic, and recurring.  yes flicking switches like a wildman sometimes solved it. however ..)
I put Mobian on the phone a day or two ago and been testing.. Call audio worked right away and after apt-get update and dist-uprade and most of the other stuff works as well such as bluetooth (not mic) and power saving.  Works like a regular phone handset now which is a relief..
It really must be drivers/config issues with PMOS.
Not to take anything away from PMOS but if you are suffering with a handset that doesnt make calls try Mobian until PMOS gets a bit further along..
#24
(11-18-2020, 12:42 AM)Xerxes 8933A/A Wrote: OK, so just to update future readers of the thread..  I had an up to date PMOS on my handset until today still with call audio issues (low volume, robot voice, cant understand - all sporadic, and recurring.  yes flicking switches like a wildman sometimes solved it. however ..)
Calls with UBports is workign out fine. Though I don't like how they are taking projects from Android and putting them on there.
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 683 10-03-2023, 06:32 PM
  installed postmarketos v23.06 no audio samlo 1 702 07-14-2023, 12:53 AM
Last Post: samlo
  pmos/phosh edge update and audio disappears robthebold 9 5,236 07-10-2022, 03:26 AM
Last Post: arkadione
  headset audio left <-> right desca 3 4,267 09-17-2020, 02:59 PM
Last Post: desca
Question Can't figure out audio routing for modem strake 4 6,350 05-22-2020, 04:46 AM
Last Post: nieral
Big Grin Standing on the shoulders of giants - my first Pine call dukla2000 3 4,275 02-19-2020, 03:52 PM
Last Post: Luke
