Help with battery!
My pinephone64 arrived today and it looks very, very cool but...I can't get the back off so I can get at the battery! I apparently need to do this to remove a piece of place over the contacts.
I found the little 'notch' on the corner, but can't work out what to do with it. I've tried pulling the front/back bits apart with my finger nail, pushing in with the tip of blunt knife (ala iphone 'pin' mechanism) but so far nothing except for some sore fingernails. I'm pretty sure I'll end up scratching the thing to death in the process of getting it open - it seems to be a talent of mine - but I just thought I'd check first to see if I'm missing something obvious.
Bye!
Mark
You only want to widen the gap a little to start with, the cover has flex, but it is easy to crack.
perhaps a butter knife, but then run a fingernail in the gap around the whole phone,
then it should be easy to remove.
You cannot remove the cover by simply lifting one corner !
It does get easier with practice, and the cover does stretch a little after removing it a few dozen times.
(09-02-2020, 11:05 PM)bcnaz Wrote: You only want to widen the gap a little to start with, the cover has flex, but it is easy to crack.
It worked, thanks a ton!
I'm still finding mine pretty hard to open after at least ten times. Since I haven't been carrying it around in the outside world yet, I've been able to resort to not having all of the little plastic latches clicked shut.
  Megi's Kernel and Battery Life biketool 3 2,136 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,607 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,533 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,215 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,034 03-30-2022, 12:02 AM
Last Post: JohnDoe
  improve battery life on pine phone beta? taoschx 0 1,066 02-28-2022, 06:24 AM
Last Post: taoschx
  Guide to power off the Pinephone on low battery Ulfnic 1 1,556 02-06-2022, 05:16 AM
Last Post: Ulfnic
Question Is there a way to increase the battery life of the PinePhone? Avisando 18 12,281 01-22-2022, 11:55 PM
Last Post: bcnaz
  Battery Charger? JesusGod-Pope666.Info 9 6,514 12-01-2021, 09:00 AM
Last Post: JesusGod-Pope666.Info
  Battery life: Maybe really a hardware issue? KNERD 34 21,807 09-23-2021, 01:11 PM
