Flash new OS on Pinephone?
Obviously a useful feature. I have a micro SD plugged in with Arch flashed on it. How do I install arch?
(09-02-2020, 04:53 PM)Potts Wrote: Obviously a useful feature. I have a micro SD plugged in with Arch flashed on it. How do I install arch?
Never-mind I am a dingus. However I won't delete this in the hopes it may help someone out...
Insert your SD card in the top slot not the bottom!
[EDIT]
It now seems that OS's that I am trying to install are not booting properly. When an image is flashed with etcher and inserted (in the top) card slot, the OS should boot on launch, correct? Currently the screen stays black and a red light appears at the top left hand of the device.
The Wiki explains most things like this: https://wiki.pine64.org/index.php?title=..._Jumpdrive
Most people prefer to flash to SD card first unless you're committed to the one OS. With a good quality SD card, you probably won't notice much difference in performance. Flashing to SD is quicker than flashing to eMMC. I'm not sure there is a way to install from SD to eMMC. I imagine the Wiki method is best.
Good luck.
Edit: I just saw your update. That's a better way to get it working. I'll leave that info above just in case someone is unsure.
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 33 24,373 04-09-2024, 01:17 PM
Last Post: donchurch
Wink PINEPHONE not booting Touchwood 2 402 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,326 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 23,891 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 1,912 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 101,149 11-17-2023, 08:37 AM
Last Post: Uturn
  Using Signal on PinePhone in mid-2023? dante404 45 12,843 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 943 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,120 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,333 10-18-2023, 08:37 AM
Last Post: luppivega
