Graphical Artifacting in Netflix?
I have installed Android 9 on my RockPro64 so that we can use it to stream Netflix (since it is Android it allows downloading of content, if I had Linux which I would prefer then we could stream live from a browser but our internet is tooo sloooow to do that!). Everything works except there is significant "artifact / artifacting" in media playback (with Netflix only? Using "NewPipe" for YouTube streaming seems OK).
Is it possible there is some configuration option needed to enable GPU / Hardware Acceleration? I can't seem to find nearly anything on the situation. I will try alternative (older) Netflix versions to see if it helps, but I suspect not....
