Phone won't charge in Mobian
Recently flashed an SD with Mobian and noticed that it isn't charging. Anyone else have similar issues? For what it's worth, I am on the most recent nightly build.
(08-30-2020, 04:59 PM)ragreenburg Wrote: Recently flashed an SD with Mobian and noticed that it isn't charging. Anyone else have similar issues? For what it's worth, I am on the most recent nightly build.
https://wiki.mobian-project.org/doku.php?id=tweaks
Quote:USB-C chargers / smart chargers not charging phone
This appears to be related to the kernel module for a chip in several USB-C-to-HDMI adapters. It can be fixed by blacklisting the module.
To fix it, create or edit the file
/etc/modprobe.d/blacklist.conf
and add the following line:
blacklist anx7688
Reboot, and smart chargers should now charge correctly.
PBP ISO / Debian Bullseye (unofficial installer)
blacklist anx7688
Thank you, that worked. I swear I looked through that portion of the documentation but must have been lazy about it.
Another possibilty without backlisting or removing the module would be to turn the phone off and then plug in the charger. Mobian will start and continue charging.
Rebooting won't do for this trick.
Hey thanks for the link, it is very interesting, for all the info there
I didn't have any problem charging. If we have the same phone and same OS, why some charge some don't? I am updating using apt every 2-3 days, never had the charging problem. Weird?
  Mobian repository status henrythemouse 16 8,551 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,829 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 114 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,891 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,766 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 616 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,800 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,872 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 614 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,964 06-19-2023, 03:02 PM
Last Post: vusra
