Video Editing
Here are my first steps with video editing with a PBP.
We really need access to hardware video codecs, but that is another story.
I installed OpenShot and started working on a 720p video.
I only added a simple image before as intro and a simple image after as outro.
The preview in OpenShot already suffered from performance issues and it is really hard to get the right timings when you want to cut a video clip.
In the end I used VidCutter to get the start and end for a clip and used the time markers in a command line with FFMPEG.
VidCutter seems to start cutting from a key frame by default and smart cutting gave a strange jump in my clip.
Here is an example of the command line and the source where I found it.
ffmpeg -ss 00:01: 00 -i input.mp4 -to 00:02:00 -c copy output.mp4
https://stackoverflow.com/questions/1844...ing-ffmpeg
At the moment video editing on a PBP is a bit like torturing yourself.
I really hope we do get access to the hardware video codecs in the future.
Have you tried Kdenlive on the Pinebook Pro? I know it works pretty good on my Raspberry Pi.
(08-27-2020, 11:53 PM)PaulQ Wrote: Have you tried Kdenlive on the Pinebook Pro? I know it works pretty good on my Raspberry Pi.
No, as long as we don't have access to the hardware video codecs, I don't see the point to explore further.
Do you have hardware acceleration active on the Pi?
I believe so.
  Video Flashing/adjusting on boot and reboot jbradley419 0 233 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,221 12-17-2023, 09:29 PM
Last Post: insideau786
  U-Boot, video console, and visual artifacts dsimic 21 18,275 03-16-2023, 07:30 AM
Last Post: Tazdevl
  Kdenlive or other video editing software?? SuttonWillow 4 4,475 05-26-2022, 09:11 PM
Last Post: IsraelRobinson
Question USB-C Video Out Issue dev 2 1,806 02-08-2022, 07:28 PM
Last Post: dev
  Video : Review of the PineBook Pro with Armbian NicoD-SBC 1 2,567 07-06-2021, 10:10 PM
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 18,008 03-12-2021, 10:46 AM
Last Post: spikerguy
  Kdenlive or other video editing software? ImmyChan 2 2,823 01-19-2021, 01:12 AM
  zoom /video application guyaire 1 3,177 07-06-2020, 06:31 PM
Last Post: jiyong
  Garbled Video Display With Multiple Operating Systems rbma 5 7,105 06-29-2020, 07:19 PM
Last Post: rbma
