Linaro /lib/modules/4.4.70/build missing
I have flashed up linaro as found on the wiki at http://files.pine64.org/os/ROCK64/debian...k64.img.xz
I am trying to install driver for PAU05. I download the linux driver from panda wireless and then follow their instructions.
I hit the point where I need to tar jxvf linuxdriver4fedora_v2.5.0.3.tar.bz2 and then make it.
When executing make, I get make[1]: *** /lib/modules/4.4.70/build: No such file or directory.
Can anyone point me in the right direction to solve this?
Further, when trying to upgrade the kernel, I run sudo apt-get install linux-image-armmp and it is successful while telling me I need to install the headers which I do... But upon reboot uname -r still shows 4.4.70. Any thoughts?
Thank you!
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,042 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 1,692 09-09-2019, 09:39 AM
Last Post: shivarj89
  build out list(s) grimace 4 4,890 11-20-2018, 12:31 PM
Last Post: grimace
  Compatible WiFi modules for Rock64 j3eeenet 8 13,286 08-08-2018, 02:06 AM
Last Post: AnythingIsFine
  Rock64 missing /sys/bus/platform/drivers/rockchip-dmc/dmc? tocirahl 2 2,988 08-04-2018, 05:07 PM
Last Post: tocirahl
  AOSP Build Steps Using github.com/ayufan-rock64/android-7.1 birender.s 15 20,328 05-09-2018, 01:20 AM
Last Post: burram
  Need help build Volumio Image for Rock64 with sound hat btwozaunt 7 8,872 09-07-2017, 12:27 PM
