Will Android be open source too?
This is the third time I've asked this, first in message, then as a comment after the pledge, but still nobody could or was willing to answer me if Android sources will be published or not. Well, the kernel sources will have to be published but I don't know if the AllWinner Android source is proprietary or not. the Mali source is closed source, if I'm not mistaken.
So please somebody tell me if there will be repositories to build Android for then PINE 64 from the AOSP source, or not.
(01-12-2016, 04:25 AM)pjt Wrote: This is the third time I've asked this, first in message, then as a comment after the pledge, but still nobody could or was willing to answer me if Android sources will be published or not. Well, the kernel sources will have to be published but I don't know if the AmLogic Android source is proprietary or not. the Mali source is closed source, if I'm not mistaken.
Allwinner A64 Android source code already available, just follow this CNX software path and you wil get it: http://www.cnx-software.com/2015/12/10/a...urce-code/.
(01-12-2016, 10:37 AM)tllim Wrote:
(01-12-2016, 04:25 AM)pjt Wrote: This is the third time I've asked this, first in message, then as a comment after the pledge, but still nobody could or was willing to answer me if Android sources will be published or not. Well, the kernel sources will have to be published but I don't know if the AllWinner Android source is proprietary or not. the Mali source is closed source, if I'm not mistaken.
Unfortunately, I don't see the Android source here. But thanks anyway.
Here is the link: http://www.murlock.org/a64/android_A64_A5.1_V1.0.tar.gz
Thank you! It only said SDK, and that it will take 2 days to download, but this link was fast.
Thank you for the info.
Thanks a question with PINE A64-LTS also interested me, how about updates?
(04-19-2018, 02:18 AM)Harlan Mueller Wrote: Thanks a question with PINE A64-LTS also interested me, how about updates?
PINE A64+ and PINE A64-LTS share sames SDK source. The only different is PINE A64+ memory configuration set as DDR3 and PINE A64-LTS sets as LPDDR3.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,861 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,743 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,854 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,999 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,069 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,624 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,345 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,922 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,556 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,386 02-10-2019, 07:44 PM
Last Post: mmmarcus
