Ubuntu on pine 64+
Is Ubuntu available for the pine 64+ the two GB version of Pine 64?
I know that for a while one had to build it.
Also, does wi-fi come standard on the Pine 64+ 2GB version?
I do not see where to buy it separately on the Pine 64 website.
Any help appreciated. Thanks in advance.
Respectfully,
Lou Reed
https://www.stdin.xyz/downloads/people/l...es/ubuntu/
Check here...
https://www.stdin.xyz/downloads/people/l...ges/linux/
There are ubuntu images that work with the 2gb model. See what Leoncito81 posted ^
Also, here is the link to all images (most up-to-date).
In regards to the module, no it doesn't come with the 2gb board. You can get it  here (may be sold out)
Do note that you can now use some 3rd party USB Wifi dongles with longsleeps kernel.
Hope this helps
I am confused about Ubuntu on the Pine 64. There is an Ubuntu version for the 1GB and the smaller memory Pine 64, but not one (or one was just released) for the 2 GB version).
So how come I can't just use the Pine 64 1 GB version of Ubuntu on the 2 GB version. The only difference is the memory size, right?
Respectfully,
Lou_Reed
My Ubuntu Xenial image works for all pine64 models. There are no different versions and never have been also never will be.
(05-25-2016, 10:18 AM)Lou Reed Wrote: I am confused about Ubuntu on the Pine 64. There is an Ubuntu version for the 1GB and the smaller memory Pine 64, but not one (or one was just released) for the 2 GB version).
Respectfully,
Lou_Reed
You can all Linux (and android) images on the Pine64 with 2gb.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,593 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 596 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,889 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,956 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,319 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,484 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,735 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,766 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,235 12-02-2019, 09:36 PM
Last Post: netHolio
  NetBSD for Pine A64(+) Luke 3 6,707 10-05-2019, 11:04 PM
Last Post: mrgtwentythree
