Which dock for dual HDMI screen
I'm wondering if anyone tried a "convergence extension" with two HDMI ports ?
Something like : https://www.amazon.com/Displayport-Ether...200&sr=8-4
With a total of 3 images displayed ?
Looks like it simply has 3 cloned outputs aside from Windows. If you are interested in 3 of the same display outputs it will probably work. I
I'm interested in 3 different images (to recycle old monitors).
The "A, B, C" configuration listed for Windows host in the product description.
If no one tried already I should be able to try something next month (if deliveries are on time).
(08-11-2020, 03:20 AM)Siltaar Wrote: The "A, B, C" configuration listed for Windows host in the product description.
I would not expect that to work.
Just to correct, it's called "Extended mode" in the description above : with Mobile monitor, 2 HDMI and 1 Display Port ; it promises 4 different images…
But I'm just looking for the dual HDMI.
Edit: Finally, I opted for this model and will have to wait my Pinephone dellivery first :-)
https://www.amazon.fr/gp/product/B08CZBT...UTF8&psc=1
@SwordfishII : What facts motivate your guess ?
(08-12-2020, 01:21 AM)Siltaar Wrote: Just to correct, it's called "Extended mode" in the description above : with Mobile monitor, 2 HDMI and 1 Display Port ; it promises 4 different images…
The "Windows" solution is likely driver/VM/virtual desktop based.
Pinephone is still fledgling in development, it is unlikely this is implemented, if even possible, when basic functionality is still being worked out.
Never seen a Linux method for doing this. The Pi 4 has dual hdmi out for dual screen.
The pinephone only has displayport via this source.
https://en.m.wikipedia.org/wiki/PinePhone
On a side note here is some stuff that might help you get going on a multi display
https://wiki.archlinux.org/index.php/mul...al_display
This and the next section in particular is how I would approach it, coupled with a script to turn off the phone display on hotplug (leaving the two monitors in a combined virtual display)
Good luck!
(08-10-2020, 06:49 AM)Siltaar Wrote: Hi,
This is not possible, PinePhone SoC, A64, only has two display engine.
  PinePhone Dock with laptop? Mikey1977Y2J 2 631 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Why do mouse, keyboard and HDMI not work with 3.th party usb-c adapters? Peter Gamma 3 4,075 03-27-2023, 01:59 AM
Last Post: Peter Gamma
  Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone Matt2020 10 4,559 03-07-2023, 12:33 PM
Last Post: emsyr
  A Pinephone case that'll actually prevent the screen from cracking mil 24 16,590 11-18-2022, 02:18 PM
Last Post: mil
  Gembird USB Typ-C to HDMI has no HDMI output when connected to PinePhone PostmarkedOS Peter Gamma 1 1,368 06-13-2022, 09:53 AM
  The PinePhone USB-C dock of the magician Martijn Braa Peter Gamma 0 926 06-12-2022, 08:24 AM
Question Keyboard Case + Convergence Dock Merc 5 3,267 04-21-2022, 10:24 AM
Last Post: zetabeta
  Convergance Dock HDMI resolution: bceverly 4 3,886 03-09-2022, 12:41 PM
Last Post: alxtrnr
  Screen/Screen Protector Whitening Issue adjf873_n-s 6 4,935 03-09-2022, 02:46 AM
Last Post: adjf873_n-s
  How to Disable on-screen Keyboard? dgiffin 4 4,016 01-20-2022, 09:02 AM
Last Post: dgiffin
