how to make 7 inch lcd work
i got one 7 inch lcd with touchscreen at https://www.pine64.pro/pine-a64-accessories/
and  flashed android 5.1 follow the wiki, but the display not work.
somebody can help me? Huh
(05-20-2016, 03:02 AM)chong Wrote: i got one 7 inch lcd with touchscreen at https://www.pine64.pro/pine-a64-accessories/
You can locate the LCD panel build for Android on wiki page. here is the download link: http://files.pine64.org/os/android/andro...ixCard.zip
Good to know. Is there a dd-like image as well (cat <image> | pv | dd of=<dev> bs=1M)?
We plan to have a new release on next week and will release DD image together.
finally i flashed phoenix card img with a windows tool, it works, thanks so much.
(05-23-2016, 02:33 AM)chong Wrote: finally i flashed phoenix card img with a windows tool, it works, thanks so much.
Please note that we will rotate the screen 180 degree on next release.
Hi
I have managed to get the android LCD version to work ok, but I was wondering if any of the others work with the LCD? Remix, Ubuntu etc?
(05-26-2016, 11:25 AM)ajsullivan Wrote: Hi
I'd also like an answer to this question too!  I don't really want to run Android - LINUX (or BSD even! :-) ) all the way for this little black duck...  Surely with 2GB RAM (I got two 2 GB boards) it would be enough to run Ubuntu Touch or at least Unity ?
How "Linuxy" are the Android builds?  e.g. can you get busybox and a shell?
This is a good question. I will check with Remix folks on LCD support. On the Ubuntu front, I have provide the LCD panel to longsleep and shipped out on last week. longsleep mentioned that he will take a look but not promise result.
Android practically build on top on Linux.
  7 inch LCD touch panel is upside down? joshpl 2 1,603 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 3,055 12-07-2019, 06:50 PM
Last Post: kodachrome
  LCD Panel Connected but does not work maipercaso 1 2,951 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 5,412 05-05-2016, 08:47 AM
