Can I use Raspberry Pi3 Power supply for Pine?
Hi all,
I'm about to receive my Pine64 by this week/next week. I didnt bought the power supply by Pine64 during pledge.
But I currently have a raspberry pi 3 running and thinking I could use Pine to replace my current rasp pi.
So can I use raspberry pi 3 power supply to power up Pine64?
The power suppl y is 2.5A. And as I know Pine need 2.0A power supply.
Will it cause trouble to Pine like overload or something?
Hope you can help me.
Thanks in advance .  Big Grin
(05-19-2016, 09:21 PM)nizam27391 Wrote: Hi all,
You can use the official Raspberry Pi 3 power supply, in fact it's recommended (if using a micro usb psu).
More amps is ok, problems come when using power supplies with less than 2 amps.
I am using a raspberry Pi supply for more than a month. It works perfectly fine.
Sent from my Nexus 5 using Tapatalk
Thanks guys..
My RPi 3 power supply is 5.1V 2.5A.
So this should be fine right?
(05-22-2016, 08:03 PM)nizam27391 Wrote: Thanks guys..
Should be fine.
I have directly connected to my Acer touch screen monitor (24") via USB and it works great.  I did the same with raspberry pi3. My monitor recognize my either of connected device and boots up.
I use a RPi power supply too. It is for the Pi2 and is rated at 5V and 2Amps. It works perfectly.
I've been using a RPi power supply too and it works wonderfully. So much so that I ordered another one so I don't have to share.
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,505 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 552 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 3,775 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 5,864 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,253 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,421 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,621 12-06-2020, 03:53 PM
Last Post: junkyj753
  Pine64+ power button PaddyChan 0 2,739 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Node Red on the Pine DonFL 0 2,733 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,204 12-02-2019, 09:36 PM
Last Post: netHolio
