Plastic around camera loose, easy fix?
I noticed that the plastic around the camera that is part of the display frame has become loose on my nearly new Pinebook Pro. It can be pulled back a bit and is loose for about 5-6 cm.
Pushing it back on doesn't seem to click it back in place, so I guess it must be broken? Odd place though, as there isn't really any reason for it to break at that point.
Anyone else noticed this?
It could lead of some dirt getting between the lens cover and the camera, so I am thinking of gluing it shut. But I first wanted to check here if anyone has a better idea.
Question Broken Camera ? angeloweb 2 1,274 11-28-2022, 09:47 PM
Last Post: angeloweb
  Plastic Failure Atton 1 1,226 08-27-2022, 06:17 AM
Last Post: Atton
  Replacing the camera? lfourquaux 1 2,176 05-26-2021, 08:24 AM
  How easy is it to add donor keyboard and trackpad? ENV 3 4,995 11-12-2020, 07:51 AM
Last Post: Kaythe
  Replacement for video cable (EDP to LCD/camera)? pnwkayaker 2 3,942 10-13-2020, 08:42 PM
Last Post: pnwkayaker
  Plastic Spacers at Hinges - Substitution hmuller 1 2,934 11-15-2019, 12:01 PM
Last Post: hdk
