A functional dock reference?
Hi all,
i'm looking for a functional dock for my UBPORT edition?
Do you have some references?
I have 2 differents models at home and they don't work for HDMI & usb.
Or maybe i have missed something... something to install or activate in the OS (test with UBport, mobian & postmarket)
The goal is to integrate the phone in a open source tablet (https://www.diskiopi.com)
Thank you.
You're probably running into a combination of the USB-C CC issue, and the lack of good documentation about how to use a dock once it's fixed. The July community update talks about setting up local workshops to fix the hardware, while documentation should improve when people get the PmOS batch with the dock hardware.
https://wiki.pine64.org/index.php?title=...e_v1.2#USB
https://www.pine64.org/2020/07/15/july-u...e-version/
(07-27-2020, 11:52 AM)wibble Wrote: You're probably running into a combination of the USB-C CC issue, and the lack of good documentation about how to use a dock once it's fixed. The July community update talks about setting up local workshops to fix the hardware, while documentation should improve when people get the PmOS batch with the dock hardware.
Thank you. You confirm what i've found on the web.
Not sure to be able to unsold the 2 chips. Undecided Maybe wait the possibility to buy an upgrade of the MB.
  PinePhone Dock with laptop? Mikey1977Y2J 2 631 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone Matt2020 10 4,560 03-07-2023, 12:33 PM
Last Post: emsyr
  fully functional keyboard with Debian/Mobian wigan 1 1,518 02-12-2023, 06:50 PM
Last Post: wigan
  The PinePhone USB-C dock of the magician Martijn Braa Peter Gamma 0 927 06-12-2022, 08:24 AM
Last Post: Peter Gamma
Question Keyboard Case + Convergence Dock Merc 5 3,267 04-21-2022, 10:24 AM
Last Post: zetabeta
  Convergance Dock HDMI resolution: bceverly 4 3,886 03-09-2022, 12:41 PM
Last Post: alxtrnr
  Convergence dock not charging pinephone mobian tecnocris 8 8,502 09-11-2021, 06:43 PM
Last Post: bcnaz
  Uses for a DoA USB-C dock (disassembly/recycling) kartynnik 3 3,533 07-10-2021, 07:16 PM
Last Post: kartynnik
Heart PinePhone / Pine Tab dock or PineBook hockleyj 5 8,466 12-10-2020, 03:47 AM
Last Post: sbl
  PineTab-style USB-C dock jfrederickson 2 3,699 12-08-2020, 11:05 AM
Last Post: nas
