Idea for making legacy X11 applications practical to use
Lightbulb
So as per usual when I'm really tired I get creative ideas. This time I think it's good enough to share the idea.
What if you could triple-tap on the screen to resize a window just like as if it was an image?
Pinch to "zoom" the window and "pan" with one finger. This way we can access small controls without tapping at impossibly small UI elements while still being able to see the full window when you're done. Pinching back out would put the window back into a scaled maximized window, just like usual.
Then you exit the window manipulation mode by triple-tapping the screen again.
In my imagination it should feel pretty intuitive. The only issue I see is that it possibly conflicts with multi-pointer aware applications, but aside from GIMP and Xournal I can't think of any major ones.
So what do you guys think? Is this worthy of suggesting upstream to Phosh/Phoc or should I go back to sleep (and finally tackle the VAAPI issues tomorrow)?
  Making a new keyboard layout Eugo 2 1,481 08-28-2022, 04:15 AM
Last Post: Eugo
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,805 08-02-2022, 03:16 PM
Last Post: treebeard
  rsyslog a bad idea? Problems with ssh, openssh-server, fail2ban Anna 7 5,248 11-14-2021, 06:20 PM
Last Post: juju
  Difficulty making calls Zebulon Walton 10 8,104 04-21-2021, 12:12 PM
  Making nextcloud sync work on the phone 3x5co 4 5,920 03-27-2021, 03:49 PM
Last Post: MarkF
