Camera doesn't work. SD-Card isn't mounted automatically
Bug
today I got my Pinephone64. Unfortunately, the SD card cannot be used. It is recognized but is not automatically mounted. The camera is also unusable. I think this is due to the incorrectly integrated SD card. The SD card is displayed under External Drives. I can only format it or remove it safely. An error appears during formatting: "Format Error. There was an error when formatting the device". I can also mount the SD card in the terminal and access the files. Only it is not automatically integrated. I could solve this problem by integrating them into the terminal. However, the camera remains unusable. The trigger button is greyed out.
Does anyone have the same experience? What can I do to make the camera usable?
The device is not really usable for me.
Thanks in advance
Pavel
I've done like here
https://forum.pine64.org/showthread.php?...0#pid72410
now sd card is automatically mounted. But the camera means "no media available". under exteral drives is sd card listed but cannot be formated etc.
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 200 04-02-2024, 11:50 AM
  install iso from sd card to emmc aular 2 292 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 909 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,317 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 6,051 02-18-2023, 02:01 PM
Last Post: _radv_
  PureTalk work with Pinephone? car46999 6 2,849 01-30-2023, 12:05 AM
Last Post: car46999
  reset button under back cover, below the camera mruser1 2 1,013 01-02-2023, 08:07 AM
Last Post: wibble
  SIM Card Slot Terror thismarty 4 1,449 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 1,983 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,401 11-23-2022, 05:19 AM
Last Post: _radv_
