Unable to mount exFAT file system
When trying to open an exFAT formatted drive in Mobian's file manager an error message pops up saying: unknown filesystem type 'exfat'
I tried installing exfat-fuse and exfat-utils, but still get the error message. Are there some additional things missing that are keeping this from working?
I know it certainly works after installing those two packages and mounting it manually. I can then access its contents using the file manager.
My SD card is mounted that way on fstab.
I am not sure if automounting exfat volumes works.
I think that was the reason I added my SD card to fstab.
(07-22-2020, 01:39 PM)fernando_c_m Wrote: I know it certainly works after installing those two packages and mounting it manually. I can then access its contents using the file manager.
Weird. I still get the same error message when trying to mount exFAT filesystems manually from the terminal. I definitely have exfat-fuse and exfat-utils installed at this point. I'm using a CE pinephone with the VCONN switches removed and haven't had any issues mounting FAT32, EXT4, and NTFS (after installing ntfs-3g) formatted SD cards or USB flash drives.
mount.exfat-fuse /dev/mmcblk0p1 /mnt/sdcard
works in my case...
works in my case...
Looks like I had just forgotten the ".exfat-fuse" when manually mounting. So I am able to mount it from the terminal now. Thanks!
  Errors when start the system kubussz 2 562 11-21-2023, 11:07 AM
Last Post: kubussz
  Unable to wake up from suspend xavi92 5 1,127 10-26-2023, 03:02 PM
Last Post: xavi92
  System won't suspend due to suspention notification user641 6 1,422 09-24-2023, 05:47 AM
Last Post: user641
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,097 07-07-2023, 03:29 AM
Last Post: jojuma
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,191 03-01-2023, 04:45 PM
Last Post: anonymous
  German Emergency Alarm System Test arno_nuehm 4 1,849 12-11-2022, 01:44 PM
Last Post: traut
  low disk space on file system root revisited benedikt55 2 1,492 09-24-2022, 10:16 AM
Last Post: benedikt55
  Unable to send messages with chatty user641 0 772 09-07-2022, 04:35 AM
Last Post: user641
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 1,721 07-16-2022, 02:28 PM
Last Post: dachalife
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 3,308 03-01-2022, 10:06 AM
Last Post: bujiraso
