SIM Card not recognized . . .
Hello everyone, just received my pine phone but it's not recognizing my SIM card.  I'm in the USA, would anyone happen to know if the phone works with MetroPCS SIM cards?  I assumed they did since metro is now t-mobile.  Thanks in advance!
(07-21-2020, 06:16 AM)finphone Wrote: Hello everyone, just received my pine phone but it's not recognizing my SIM card.  I'm in the USA, would anyone happen to know if the phone works with MetroPCS SIM cards?  I assumed they did since metro is now t-mobile.  Thanks in advance!
I was told to try Mobian as a mobile OS, you can find it the forum post here,  https://forum.pine64.org/showthread.php?tid=9850
or their website https://mobian-project.org/
I too have problems with celluar on my Pinephone. For me I use T-mobile in the USA.
I'll try that, many
thanks!
I've used mine on Metro and T-mobile. They both work, being the same backend. Only complaint being you have to call metro to swap your sim, t-mobile you don't of course.
(07-22-2020, 08:39 PM)rocket2nfinity Wrote: I've used mine on Metro and T-mobile. They both work, being the same backend. Only complaint being you have to call metro to swap your sim, t-mobile you don't of course.
Thank you, appreciate it!  Was originally concerned because the phone had indicated that "no SIM card was installed".  So, thought there may have been a hardware conflict.  I'll shoot metro a call then, thanks again!
  install iso from sd card to emmc aular 2 291 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 908 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,317 06-11-2023, 12:30 AM
Last Post: AndyM
  Device Unable To Read MicroSD Card _radv_ 19 6,043 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,447 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 1,974 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,399 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 5,092 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 2,177 02-12-2022, 11:09 AM
Last Post: dekrets
  I just got to find phone in my sd card won't read Tyro 5 5,961 11-15-2021, 01:11 AM
Last Post: alexenwaston
