[split] U-Boot with NVMe support, keyboard & display working
#81
(01-20-2021, 01:37 AM)as400 Wrote: @moonwalkers - MrFixit's uboot is basically Rockchip BSP uboot (and ATF). It has some binary blobs (afaik in ATF) from Rockchip doing god knows what. The difference is that, when using uboot from this thread, you're running completely open source uboot and ATF with no binary blobs from SBC manufacturer.
That's not what my question was about. I understand perfectly well there are binary blobs in ATF in MrFixit's BSP uboot vs fully open source other builds of u-boot, and I'm all for getting fully open source version up to 100% feature parity and then some with BSP uboot/ATF. My question was where that ATF is supposed to be, so that, if possible, I could try combining the blobbed ATF with working suspend with the u-boot version that shows the boot menu until fully open-source suspend is working. Am I making sense?
This message was created with 100% recycled electrons
Interesting idea.
Rockchip does not publish sources of their TF-A. Just binaries.
I have compiled 2021.01 u-boot with Rockchip blob. If you feel like it you can test drive it.
https://gitlab.com/as400l/pbp-uboot-disp...sting_only
Report how it goes. I have not tried it.
Does this support nvme booting?
@plumlis - I'm, not sure if you're asking about "normal" versions or the one with the Rockchip blob. Answer for "normal" is yes. For the one with Rockchip blob answer is yes it should.
In case of Rockchip blobbed - I had no time to test it yet - so consider it highly experimental. Expect problems. I have only one pbp and I'm daily driving the thing Smile
  uboot wont boot to SD card after upgrade jbradley419 7 758 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 276 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,171 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 655 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 567 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 743 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,146 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,029 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,823 08-03-2023, 03:30 PM
  power on Pinebook Pro mainboard without keyboard? papable 0 827 07-20-2023, 11:06 PM
Last Post: papable
