OpenWRT installation guide for RockPro64
Hi there,
I’d like to install OpenWRT in the PINE RockPro64 (followed the installation instructions here: https://openwrt.org/inbox/toh/pine64/pin...pro64_v2.1) but I have a problem now.
I’ve downloaded the OpenWRT image from here: https://downloads.openwrt.org/snapshots/...hip/armv8/ and flashed it into a 64GB microSD card.
When I insert the microSD card to RockPro64 and plugged in the power, there is no response. The display was black and showed nothing.
Does anyone install OpenWRT in RockPro64 before? Can someone point me in the right direction? Thanks in advance!
I have not put openwrt on the RockPro64 yet, although it sounds like a bit of an overkill. What I have done is install it on a raspberry Pi 4...You may of course just say that the Pi is just as powerful and also an overkill!!
I am doing the install headless. Openwrt defaults to 192.168.1.1 as a static address and you should be able to ssh into it as root. Can you do that?? I started with the Pi behind my ISP's router and had to change a few settings to be able to see the internet and do the required updates and installs.
So, first question. Can you ssh into your RockPro64?
RockPro64 v2.1, NAS Case with SATA card
Raspberry Pi 4's doing various jobs
Jetson Nano to learn about AI
  Installing Wifi drive for the RockPro64 John45595 0 307 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 756 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,249 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 889 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,323 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,824 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,650 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,019 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,788 10-21-2022, 07:44 AM
Last Post: rapier1
