GloDroid (Android-13)
#31
(09-04-2020, 05:42 AM)nas Wrote:
(09-03-2020, 07:23 PM)branon Wrote: Feels like two separate issues to me. Can you confirm if the release linked in your post is intended to be used with the 3 GB variant?
I suspect you're right - you can try generating a flashable image as described here while we await confirmation from the developer.
Edit: 3gb version should be compatible - have you succesfully booted another distro from the sd card?
Different person, but I could not boot on a 3gb GloDroid image.  I've tried both deploy-to- images, as well as the generated flashable image.  They all result in the same outcome.  The phone turns the on, with the LED red, and that is it.
I'm successfully able to boot off of the SD card from Mobian, and PostmarketOS as well as off of the eMMC for both distros.
I believe the 3gb memory difference has to be supported by code changes from this commit: http://u-boot.10912.n7.nabble.com/RFC-PA...16975.html
(09-05-2020, 07:14 PM)czero Wrote: I believe the 3gb memory difference has to be supported by code changes from this commit: http://u-boot.10912.n7.nabble.com/RFC-PA...16975.html
Yes, there's a build to test that here.
Is there currently a known bug where pressing the power button doesn't turn the screen off? And the screen never turns off due to inactivity? I didn't find anything on the github issues, but I didn't know if it was just my install or a known thing
(09-06-2020, 08:35 PM)czero Wrote: Is there currently a known bug where pressing the power button doesn't turn the screen off?  And the screen never turns off due to inactivity?
Does it only happen when plugged into a pc? I suggest reporting it as a new issue.
You can also run this command to check your device version is being picked up correctly.
I'll create a new issue, then, thanks!
Just for clarification, I'm Count042 on github, so I've posted the output of that command on the associated issue for the 3gb version.
for what i have seen on other oses, u-boot has to be pached to be able to boot on the 3g ram model. So until they update the build with the patched u-boot will not be possible to boot it on the 3g model.
(09-09-2020, 08:28 AM)paju1986 Wrote: for what i have seen on other oses, u-boot has to be pached to be able to boot on the 3g ram model.
Yes, I think at least a couple 3gb owners including @czero  have got the patched build working.
Android-11 early build available.
https://github.com/GloDroid/glodroid_man...-670354906
(09-16-2020, 06:34 AM)rsglobal Wrote: Android-11 early build available.
Yes, this is pretty darn cool.
I got the RIL + GPS partially working in glodroid 0.4
It needs much more work + cleanups to get it fully working and not break
other glodrod devices
    Make and receive calls are working
    Audio/mic in call are not working
    SMS/MMS are not working
    Mobile data is not working
    GPS fix will need ~20 min
Pictures;
https://ibb.co/LgZZ9kZ
https://ibb.co/b7DqpB3
https://ibb.co/L5ZCkWj
https://ibb.co/rpqdXWH
https://ibb.co/9rXyhzr
https://ibb.co/fvWQ2mQ
https://ibb.co/JHT15VZ
https://ibb.co/Kh6Gk0v
Changes:
https://github.com/bauner/glodroid_devic...93718c8434
https://github.com/bauner/glodroid_forks...a3cc4a80e4
Test Image:
https://androidfilehost.com/?fid=8889791610682939941
  GloDroid (Android-14) GaryM 1 100 04-17-2024, 08:39 AM
Last Post: GaryM
Tongue Android Auto on Pinephone via Waydroid: a pipe dream? slondr 1 2,018 11-06-2022, 01:46 PM
Last Post: wibble
  difference between android and linux? vanja 3 2,104 09-16-2022, 07:43 PM
Last Post: TRS-80
  Android and Google Play Store on a PinePhone? Solra Bizna 22 40,888 11-01-2021, 07:11 AM
Last Post: digitalmouse
  Easiest way to use Android applications on Pinephone esud 4 8,479 06-21-2021, 04:52 AM
Last Post: vanja
  Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) 4w7gvrvsjcyvd 0 1,822 01-30-2021, 06:48 PM
Last Post: 4w7gvrvsjcyvd
  pine phone came with android? andrewiassur 1 3,332 04-11-2020, 02:06 PM
Last Post: fire219
