Non-booting SD
I am trying to copy the Manjaro KDE 20.06 image to an SD as step one in creating a 128G eMMC. Have been doing so for over a week.
I was able to create an XFCE SD and eMMC with no problem. Both worked fine. I've tried all the methods I have seen on the forums, but always end up with a non-booting KDE SD and a perpetual green led. Well, all methods but the installer script at https://gitlab.manjaro.org/manjaro-arm/a...-installer. That requires binfmt-qemu-static, which is not in the Arch repository.
So I'm at a standstill for the time being. My PBP is still working fine with the original KDE 64G eMMC or the XFCE 128G eMMC that I made. The XFCE UI is just not what I need.
I'm getting ready to see if a PBP will work as a frisbee. But, until I get to that point, has anyone any ideas that might prevent a flying PBP (not really, I quite like it)?
Big edit.
All is well. Boot problem resolved. It was a matter of paying attention.
Today I created a new KDE image for my SD using the Raspberry Pi Imager on my Mac, which works great with no dd, etc., although dd works fine, too. I then tried to boot it and got the perpetual green led again. OK, only thing left was to turn off eMMC. Did that, and poof! Booted as it should. That's an important step, because the machine remembers last boot.
I powered down, switched eMMC back on, and rebooted. Worked fine because the machine remembered it booted last from SD.
Next, I downloaded another image and check file, did all the check and prep, and wrote it with dd to the eMMC. Powered down, removed SD (getting smarter), and restarted. Perfect. Running KDE from my new 128G eMMC.
This was not wasted effort. I learned a lot from the process.
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,858 06-01-2023, 10:58 AM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,480 04-23-2023, 06:58 AM
Last Post: acruhl
Exclamation PineBook Pro shuts down immediately after booting zogkarndon 5 1,960 01-10-2023, 10:16 AM
Last Post: Perl6_user
  Total Noob. Need help booting from SD Mattchublean 18 13,349 07-23-2022, 11:54 PM
Last Post: LivingLinux
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,460 05-26-2022, 11:36 PM
Last Post: strongtz
  PInebook not booting with eMMC enabled aragaer 4 4,215 10-25-2021, 09:11 PM
  Manjaro i3 Edition not booting mtndew 0 1,570 08-23-2021, 06:21 PM
Last Post: mtndew
Video Problem Booting from SD card ezryder324r 0 1,454 05-19-2021, 02:42 PM
Last Post: ezryder324r
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,748 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Booting to sdcard stopped working after emmc flash techiedog 3 3,910 12-31-2020, 06:30 PM
Last Post: Anarethos
