Pinebook Pro sleep issue (hinge?)
I have a 2020 PBP running Manjaro Linux it shipped with. If I do not close the lid completely (leave a half inch gap) the pinebook sleeps as expected. However If I close the lid completly the pinebook screen comes back on and stays on. Is the hinge sensor misaligned perhaps? can this be adjusted manually by removing the bottom plate?
When the "lid close" event is set to just blank the screen it works fine for me (it stays off) but when I set the lid close event to "Sleep" the pbp seems to already be "Woke" when I flip it open. Not sure if my refrigirator light actually goes off either though.
I've noticed there is a magnet in the screen bezel (bottom right) Using another magnet I can toggle the switch (right of backspace key). It could be they are not perfectly alligned and the bezel magnet overshoots the target a bit but because it's a disk shaped magnet the field extending from the edges may be the opposite polarity.
  Pinebook Pro Initial Impressions kunger 443 584,847 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,238 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 377 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 280 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 273 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 206 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 637 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 707 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,479 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,171 12-15-2023, 02:11 PM
