Camera support progress
A few interesting patches by megi have made their way to the pine64 kernel lately, bringing improved drivers for the pinephone cameras.
With a couple of extra hacks on top of that, and an experimental build of gnome-camera, support for the back camera should be working "out of the box" with the next nightly build Smile
This is far from perfect, and should be regarded as some kind of "technology preview": image resolution is 720p only, and the quality is really poor atm.
Still, I believe this is a major step forward!
You can test by first upgrading your system, then running the following command:
sudo apt install gnome-camera
(a reboot is required)
Enjoy!
.jpg   camera_test.jpg (Size: 149.58 KB / Downloads: 576)
Great news if camera support is making progress !
I've wanted to eagerly give it a try, updated the packages to the latest version, installed gnome-camera and rebooted,
but it doesn't seem to be working on my device (mobian-pinephone-20200704 flashed to the eMMC and updated several times since):
I'm getting a black viewfinder and clicking the capture button doesn't seem to record any image (Should they be stored in Pictures ?).
I've noticed that during app launch, there are a couple of clicking noises (if it might help).
Thanks for the great work on Mobian !
(07-06-2020, 10:06 AM)a-wai Wrote: Hello,
Enjoy!
Doesn't work for me
I did an apt update + apt upgrade + sudo apt install gnome-camera + Reboot
Camrea app is there , but when started the camera doesn't work
I see the app + round trigger button + but screen is black ... aka. no camera pixels seen.
PP CE + latest updates as of 20 min ago
uname -a
Linux mobian 5.7-pinephone #5.7.0+pinephone5 SMP PREEMPT Mon Jul 6 15:28:18 CEST 2020 aarch64 GNU/Linux
/Bingo
(07-06-2020, 12:15 PM)bingo600 Wrote: Doesn't work for me
uname -a
/Bingo
it's not working for me.
Damn... Can you post the outputs from the following commands please:
dmesg | grep -E "(csi|ov5640)"
sudo systemctl status pinephone-camera-setup
media-ctl -p
mobian@mobian:$ dmesg | grep -E "(csi|ov5640)"
[ 1.428226] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[ 1.430819] avdd-csi: Bringing 2900000uV into 2800000-2800000uV
[ 1.433106] dvdd-csi: Bringing 700000uV into 1800000-1800000uV
[ 4.144568] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[ 8.168327] sun6i-csi 1cb0000.csi: creating ov5640 3-004c:0 -> sun6i-csi:0 link
[ 8.191390] sun6i-csi 1cb0000.csi: creating gc2145 3-003c:0 -> sun6i-csi:0 link
[ 3730.363063] sun6i-csi 1cb0000.csi: Unsupported pixformat: 0x56595559 with mbus code: 0x2006!
[ 6667.346819] sun6i-csi 1cb0000.csi: Unsupported pixformat: 0x56595559 with mbus code: 0x2006!
mobian@mobian:$ sudo systemctl status pinephone-camera-setup
[sudo] password for mobian:
● pinephone-camera-setup.service - Configure PinePhone Camera
Loaded: loaded (/lib/systemd/system/pinephone-camera-setup.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2020-07-06 12:57:27 MDT; 2h 34min ago
Process: 1510 ExecStart=/usr/sbin/pinephone-camera-setup.sh (code=exited, status=127)
Main PID: 1510 (code=exited, status=127)
Jul 06 12:57:27 redtail systemd[1]: Starting Configure PinePhone Camera...
Jul 06 12:57:27 redtail pinephone-camera-setup.sh[1510]: /usr/sbin/pinephone-camera-setup.sh: 4: media-ctl: not found
Jul 06 12:57:27 redtail pinephone-camera-setup.sh[1510]: /usr/sbin/pinephone-camera-setup.sh: 5: media-ctl: not found
Jul 06 12:57:27 redtail pinephone-camera-setup.sh[1510]: /usr/sbin/pinephone-camera-setup.sh: 8: media-ctl: not found
Jul 06 12:57:27 redtail pinephone-camera-setup.sh[1510]: /usr/sbin/pinephone-camera-setup.sh: 9: media-ctl: not found
Jul 06 12:57:27 redtail systemd[1]: pinephone-camera-setup.service: Main process exited, code=exited, status=127/n/a
Jul 06 12:57:27 redtail systemd[1]: pinephone-camera-setup.service: Failed with result 'exit-code'.
Jul 06 12:57:27 redtail systemd[1]: Failed to start Configure PinePhone Camera.
mobian@mobian: $ media-ctl -p
-bash: media-ctl: command not found
(07-06-2020, 03:03 PM)a-wai Wrote: Damn... Can you post the outputs from the following commands please:
media-ctl -p
[ 1.428250] dovdd-csi: Bringing 3300000uV into 1800000-1800000uV
[ 1.430576] avdd-csi: Bringing 2900000uV into 2800000-2800000uV
[ 1.432691] dvdd-csi: Bringing 700000uV into 1800000-1800000uV
[ 4.189317] i2c-gpio i2c-csi: using lines 141 (SDA) and 140 (SCL)
[ 9.283883] sun6i-csi 1cb0000.csi: creating gc2145 3-003c:0 -> sun6i-csi:0 link
[ 9.293871] sun6i-csi 1cb0000.csi: creating ov5640 3-004c:0 -> sun6i-csi:0 link
[ 10.263488] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[ 45.362815] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[ 46.621344] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[ 46.919337] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[ 48.004875] sun6i-csi 1cb0000.csi: Direct firmware load for gc2145-init.bin failed with error -2
[ 48.576993] sun6i-csi 1cb0000.csi: Unsupported pixformat: 0x56595559 with mbus code: 0x2006!
Active: failed (Result: exit-code) since Mon 2020-07-06 23:42:59 CEST; 3min 57s ago
Process: 1519 ExecStart=/usr/sbin/pinephone-camera-setup.sh (code=exited, status=1/FAILURE)
Main PID: 1519 (code=exited, status=1/FAILURE)
juil. 06 23:42:59 mobian systemd[1]: Starting Configure PinePhone Camera...
juil. 06 23:42:59 mobian pinephone-camera-setup.sh[1534]: Unable to setup formats: Invalid argument (22)
juil. 06 23:42:59 mobian pinephone-camera-setup.sh[1537]: Unable to setup formats: Invalid argument (22)
juil. 06 23:42:59 mobian pinephone-camera-setup.sh[1538]: Unable to parse link: Invalid argument (22)
juil. 06 23:42:59 mobian pinephone-camera-setup.sh[1543]: Unable to parse link: Invalid argument (22)
juil. 06 23:42:59 mobian systemd[1]: pinephone-camera-setup.service: Main process exited, code=exited, status=1/FAILURE
juil. 06 23:42:59 mobian systemd[1]: pinephone-camera-setup.service: Failed with result 'exit-code'.
juil. 06 23:42:59 mobian systemd[1]: Failed to start Configure PinePhone Camera.
media-ctl -p
Media controller API version 5.7.0
Media device information
driver cedrus
model cedrus
serial
bus info platform:cedrus
hw revision 0x0
driver version 5.7.0
Device topology
- entity 1: cedrus-source (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Source
-> "cedrus-proc":0 [ENABLED,IMMUTABLE]
- entity 3: cedrus-proc (2 pads, 2 links)
type Node subtype Unknown flags 0
pad0: Sink
<- "cedrus-source":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "cedrus-sink":0 [ENABLED,IMMUTABLE]
- entity 6: cedrus-sink (1 pad, 1 link)
pad0: Sink
<- "cedrus-proc":1 [ENABLED,IMMUTABLE]
Right, this should be fixed now, an new update+reboot cycle should get you there Smile
Sorry about the mess...
It's working as of right now. Initially there was no video shown and had the same output posted above.
Anyhow laggy, but works.
Edit: Awesome work, so far Mobian has been the experience I was looking for. Thanks.
(07-06-2020, 03:50 PM)a-wai Wrote: Right, this should be fixed now, an new update+reboot cycle should get you there Smile
Thank you @a-wai...it works
  mobian, pinephone camera, and megapixels dawg161 18 1,742 03-26-2021, 12:34 PM
Last Post: calinb
  no camera,streaming after update rvh 0 172 03-21-2021, 08:02 AM
Last Post: rvh
  PSA: Transition in progress - don't update ! a-wai 46 13,782 11-20-2020, 10:37 AM
Last Post: Gribouille
  Progress (and Thank you) Zoomzit 0 433 11-12-2020, 01:14 PM
Last Post: Zoomzit
  Camera app down, megapixels up daniel 4 1,563 09-22-2020, 07:34 AM
Last Post: bcnaz
  Camera use on Mobian/Brave Heart bcnaz 6 2,463 07-08-2020, 02:37 PM
Last Post: bcnaz
  Camera test on Phosh Luke 4 3,191 05-26-2020, 02:44 AM
Last Post: a-wai
