Keyboard transplant issues
So I bought an OG ISO Pinebook Pro and then bought an ANSI keyboard when it became available. Yesterday, I had time to transplant everything from the ISO top case to the ANSI top case.
Everything appears to be working, but I am getting crazy keycodes back from the new ANSI keyboard.
q>nil, w>w, e>s, r>e, t>d, y>r, u>f, i>t, o>y, p>h, [>j, ]>-
a> nil, s>nil, d>q, f>z, etc.
Is there anything I need to do to flash something on the board to get this working correctly? Is the ribbon not installed properly (although I'm pretty sure I did it correctly).
I'm using Chromium at the moment, fwiw.
Thanks.
Information
You definitely need to flash the ANSI keyboard firmware onto your Pinebook Pro if you switch keyboard types. I pasted the instructions from the wiki below. I am not sure if it is possible to run these instructions on Chromium OS, so I would highly recommend grabbing one of the Ubuntu releases from here: https://wiki.pine64.org/index.php?title=...re_Release, loading it onto an SD card, and running the commands listed below from there. Good luck!
ANSI Model
  • NOTE: Running step-1 on the ansi keyboard model will make the keyboard and trackpad inaccessible until step-2 is run, so an external keyboard must be connected to complete the update on this model!
git clone https://github.com/ayufan-rock64/pineboo...rd-updater
make
Step 1
sudo ./updater step-1 ansi
sudo reboot
Step 2 (after reboot)
sudo ./updater step-2 ansi
sudo reboot
When done, if some of the keys produce in-correct characters, please check your OSes' language settings. For ANSI users, the default OS shipped with English UK as the default language. You can change it to English US if desired.
Thanks for the quick reply!
I though the firmware might be part of the keyboard/top case assembly, but if it's part of the logic board, that makes total sense.
I'll flash my SD and get cracking right away.
That did it. Thanks a bundle!
  Pinebook Pro charging issues tomekdev 1 601 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,604 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 696 06-04-2023, 02:51 PM
Last Post: Besouro
  Touchpad Issues - August 2022 Run SteveCaruso 5 2,952 12-14-2022, 11:00 PM
Last Post: doug
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 4,896 06-19-2022, 09:47 AM
Last Post: Rosbeefandino
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,107 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,674 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,455 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,328 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,834 08-09-2021, 09:20 PM
