Developer Guide to Port Applications to Pinephone anywhere?
I'm a little curious if there is a dev guide anywhere with some information on porting applications over to pinephone.
Such as some basic information on what to change in order to compile GUI-based applications to run with Phosh on mobile?
Is there any guide with some information on this anywhere?
CLI-based is probably pretty easy, but I'm just curious about the GUI based stuff and optimizing it for the small screen.
I have a UBPorts edition so I can test stuff out Smile
Edit: I figured it out and found some resources on UBPorts if anyone has anymore sources of info to help with porting apps feel free to post some info..
  PinePhone - boot from microSD laserpyramid 6 535 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 339 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 228 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,865 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,775 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 599 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,333 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 490 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,672 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,935 12-04-2023, 02:14 AM
Last Post: Peter Gamma
