Unable to send SMS on US Mobile GSM (T-Mobile MVNO)
I have just briefly had a look through the code.
What appears to happen is that chatty has no SMS protocol enabled at that time making the "+" button greyed out.
Presumably chatty does not "find" the modem on startup and therefore has no SMS support.
Could you try doing the following:
After boot wait a little bit to make sure the modem is online and connected to your carrier (I don't think you necessarily need to be connected - I could be wrong though).
then run "killall chatty" a few times until you get "no process found" and then start chatty again from the UI.
I have the suspicion that the "protocol detection" is only run once on startup and maybe it is during a time (since a daemon is autostarted)
where the modem is not yet "fully up". Obviously when you receive a new SMS chatty will then know that SMS work (if that makes sense) ;)
(07-09-2020, 01:04 AM)devrtz Wrote: I have just briefly had a look through the code.
where the modem is not yet "fully up". Obviously when you receive a new SMS chatty will then know that SMS work (if that makes sense) Wink
Whoa !
My phone was sitting for 5 or 6 hours and apparently did an auto-update.
The signal strength icon has completely disappeared,   no modem function at all now.
I cannot even make a phone call...
When I restart the phone,  only sometimes the signal icon shows for an instant, but does not populate with a signal
  THEN  when I sign-in there is no signal indicator at all.
I have just installed the July 09 nightly release,
I have a working modem again,  but still have the problem of text App/chatty (not initializing )
  I tried leaving an un-opened text in the App and re-starting the phone but that did not help.
   >  Though if I receive a text while my Brave Heart is turned off,  it will activate/initialize when I turn it on.
I have no idea when that was  "Changed"  but it would seem to be fairly recent, as maybe just a few weeks back...
   That did just "work"  in the past.
Thanks for your keen observations,  could this possibly only affect the version 1.1 motherboards ? (Brave Heart )
  >   I would think more people would be complaining if it affected everyone.
BC
Must have been when I updated the package to the latest chatty release.
And I don't think this would be limited to BH users (I could be wrong though!)
Did you try killing the process and starting chatty fresh as I described in the last post?
For this to work your modem needs to be detected though (the cellular icon should appear,
but does not necessarily have to have a connection I think)
Edit: If we can't figure out what the problem is, we should open an issue here
Edit^2: Just come across this issue myself and confirmed it can be "solved" by killing and restarting chatty.
Have opened an issue
Updating to the newest purple-mm-sms package should fix your issue!
It now watches for changes in ModemManager.
Btw we kind of hijacked the thread a bit.
Next time this should be discussed in a different thread.
Maybe the mods can move it?
I was away from service over the weekend...
  I Just made a copy of the July 13 nightly.... and flashed it.
I still need to initialize the text app using my second phone.  (?)
IT works just fine once it is initialized.  ( until the next boot )
I am wondering how many others have not been able to use their text ?
    ( How many have a second phone to initialize their text App ? )
BC
I am testing US Mobile service and also unable to send SMS
Running mobian, nightly from yesterday, but image from week ago had the same problem
In journalctl output I see
...ModemManager[1615]: transaction 0xd aborted, but message is not abortable
...ModemManager[1615]: [/dev/cdc-wdm0] No transaction matched in received message
Same issue regardless of using Chatty vs modem-manager-gui
(07-18-2020, 05:49 PM)radarman Wrote: I am testing US Mobile service and also unable to send SMS
That's really interesting, I wonder if our issue was specific to US Mobile somehow.
At any rate, I just re-flashed my phone using the new FDE installer, and sending SMS messages from chatty works fine now!
  Mobile internet via cellular network mostly not working Anna 18 9,726 01-19-2024, 02:59 AM
Last Post: anonymous
  Unable to wake up from suspend xavi92 5 970 10-26-2023, 03:02 PM
Last Post: xavi92
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 1,022 07-07-2023, 03:29 AM
Last Post: jojuma
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,457 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,271 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,364 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 16,325 10-29-2022, 09:16 AM
Last Post: treebeard
  Unable to send messages with chatty user641 0 724 09-07-2022, 04:35 AM
Last Post: user641
  Amberol Mobile Music player(flatpak) biketool 0 885 06-19-2022, 07:16 AM
  sharing mobile data through usb tethering deb75 7 4,078 02-26-2022, 08:52 AM
