Release: PinePhone model file (Blender)
I just finished a 3D model of the PinePhone done in blender you can use freely for your projects, for example for renderings.
Mind that the whole back side should be accurate as the CAD files released by Pine64 were used. However the front side is not perfectly accurate, angles of the screen and the screen glass were estimated so use with caution when using the file to create equipment such as cases or similar (you have been warned!).
The .blend file can be found under: https://www.thingiverse.com/thing:4520124 (the forum's file attachment quota doesn't allow me to upload it here).
There are two glass parts, one is the LCD on the front and one is the protection plate of the camera on the backside. These parts do actually have a glass shader and objects behind them.
Example renderings:
.png   pp1.png (Size: 210.32 KB / Downloads: 403)
.png   untitled3.png (Size: 461.49 KB / Downloads: 350)
If you have wishes or need adjustments such as logos or certain angles please don't hesitate to contact me.
  PinePhone - boot from microSD laserpyramid 6 553 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 346 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 231 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,963 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,788 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 602 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,352 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 494 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,681 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,947 12-04-2023, 02:14 AM
Last Post: Peter Gamma
