pCloud Client on PBP w/ Manjaro?
Is it possible to install pCloud client on PBP with Manjaro?   I tried the installer and manual installation but neither worked.
Which pcloud are you trying to install? I see the AUR has a pcloud-drive. It appears the official AppImage is x86 only. You may try altering the PKGBUILD for pcloud-drive in the AUR to include the aarch64 architecture. It's not guaranteed to work, but it might.
Thanks! I am on the steep part of the learning curve here. Any advice on a tutorial to learn how to try this would be much appreciated.
  Manjaro Sway Theme Broken Eighty8 1 168 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,607 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 215 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,916 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 746 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,913 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,853 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 709 08-18-2023, 02:06 AM
Last Post: juliamenendez
