Python IDEs in Manjaro on the PBP
Linux novice looking to do some python development on my PBP.
On Windows, I primarily use Sublime Text or Spyder.
Unfortunately, Sublime Text does not appear readily available on aarch64 and I have been encountering errors when trying to launch Spyder in Manjaro (I suspect it is an unsupported qt version).
What python IDEs would this community recommend?
I'd start with Geany, it's available in the package manager for most distros that run on the PBP and is a great balance of speed and features. You might want to also check out VSCodium, the open-source build of VSCode.
(06-30-2020, 09:47 PM)qchapter1 Wrote: I'd start with Geany, it's available in the package manager for most distros that run on the PBP and is a great balance of speed and features.  You might want to also check out VSCodium, the open-source build of VSCode.
Thanks for the suggestions!
I like how Geany has a similar UI to Sublime Text (I might play around with it later).
I'll give VSCodium a spin first, as it seems to be a bit more platform agnostic - thanks to the open-source build. I can learn it once and use it both on Linux/Windows!
Update: I was successfully able to install VSCodium via AUR.
Everything went smoothly following the official guide.
I tried to install Codium and have yet to do so successfully.  I tried to install Geany via snap and could not get it installed that way either.  Ultimately I installed Geany via:
sudo pacman -S geany
https://discover.manjaro.org/applications/geany
  Manjaro Sway Theme Broken Eighty8 1 260 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,719 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 305 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,074 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,152 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 386 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 859 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,994 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,947 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 750 08-18-2023, 02:06 AM
Last Post: juliamenendez
