Arch Linux ARM on PinePhone
What's working
  • Everything
What's not working (or not properly working)
  • You tell me.
Downloads:
User/Pass: alarm/123456
The same password is also how you unlock the device on first boot, this can be changed later in the settings.
All downloads are available on: https://github.com/dreemurrs-embedded/Pi...h/releases
Discussion Channels:
  • Discord: revoked
  • Matrix: #archlinux-pinephone:kde.org
  • Telegram: @archlinux_pinephone
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
I've pushed out a new image, here is the changelog:
Arch Linux ARM (20200705):
  • Kernel upgraded to 5.7
  • Phoc/Phosh upgraded to 0.4.0
  • Proximity sensor now works under Phosh!
  • Now using NetworkManager for DNS resolving instead of systemd-resolved
  • No more 30 seconds delay on shutdown for PinePhone 1.2 (Community Edition)
HOLD YOUR BREATH.
Nice. Ill try it a little later today.
Sent from my Pixel 3 using Tapatalk
Waiting my SD Card then i'll try !
If SMS and Call works, i'll litteraly use it as daily driver.
New release of Arch Linux ARM PinePhone (20200711):
Arch Linux ARM (20200711):
  • Now bundles the ANX7688 firmware (for use with devices that has CC-pins fixed)
  • SoC thermal sensor now fixed, and the device LED will blinking red on kernel panic.
  • Squeekboard now have a new keyboard layout for Terminal-based applications!
  • Call routing is now fixed.
  • Added a flashlight app, now you can find your lost keys in the dark!
  • CIFS is now enabled in kernel.
  • Added Telegram support to Chatty.
  • scale-to-fit helper script for scaling wayland applications to fit with screen.
HOLD YOUR BREATH.
(07-11-2020, 02:04 PM)Danct12 Wrote: [*]Added a flashlight app, now you can find your lost keys in the dark!
do you need to reflash or is updating enough? I'm not able to locate a flashlight app, either in the menu, nor in the software manager
also, there is a sizing issue where apps ignore the existence of both the top and bottom bars and just grow their UI to whatever size anyway. the bottom bar is ignored by most apps, and the top bar is ignored by most pop-up windows
edit: to add the flashlight app, install "flashlight" using pacman. it's located in the phosh repository. note: it appears to be non-functional
[*]do you need to reflash or is updating enough? I'm not able to locate a flashlight app, either in the menu, nor in the software manager
You need a updated kernel to use the flashlight.
HOLD YOUR BREATH.
does the kernel not update from the /pine64/ repo or do you ship different kernels with the builds?
flashing the new image does indeed get the flashlight app to work
(07-12-2020, 08:25 PM)hiimtye Wrote: does the kernel not update from the /pine64/ repo or do you ship different kernels with the builds?
The latest image is using /pine64/ repo, and the kernel is from there.
About flashlight, you might have probably used an old version of the flashlight which doesn't have udev rules.
HOLD YOUR BREATH.
New image (20200715): https://github.com/dreemurrs-embedded/Pi...g/20200715
  • Updated crust firmware
  • cheese camera app removed, soon to be replaced.
  • Added initial setup screen
  • Alternative version of gnome-contacts which has calls/sms button
  • Added a PDF reader
  • Fixed YouTube playback on Epiphany
  • Workaround for Bluetooth suspend bug
  • Upgrade Phosh to 0.4.1
  • Upgrade Chatty to 0.1.14
HOLD YOUR BREATH.
  Updating Arch Linux _radv_ 8 818 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,249 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 780 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,941 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,863 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 907 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 846 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,139 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,425 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,398 10-17-2022, 07:22 AM
Last Post: Chief
