Red Pinephone USB-C cable.. just for charging, right?
Hi everyone,
Just wanted to check in and see what others have found with the cable received with the PinePhone. Mine is red, I thought it was a standard USB-C cable but it turns out it only works for charging. I tried plugging in this cable to an android phone and linux PC, the lsusb command comes up with nothing/can't find device. Switched to another cable to find that it does work as a standard usb cable, data transfer/charge capable.
Hopefully it is as designed, just for charging.
(06-30-2020, 01:55 PM)djvinniev77 Wrote: Hi everyone,
That's odd, from my experience it's perfectly capable of Data Transfer. Works when I use it for my 1 TB external SSD and it works when running JumpDrive on the microSD card to install an OS on the eMMC.
Works for data for me too. It even works so well that I am currently using it as a link cable for my Oculus Quest.
The PinePhone USB-C cable color RED indicate this is a power cable. This cable has USB 2.0 D+ and D- line due to some power supply using this two data line to determine supply current. The power lines (VBus and Ground) inside this cable have been thicken, capable of handles up to 4A and also low resistor value to minimize power loss (voltage drop). You can use this cable as an USB 2.0 cable.
  Case for Pinephone totilele 13 7,207 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,744 02-19-2024, 07:30 AM
Last Post: theResonant
  PinePhone Dock with laptop? Mikey1977Y2J 2 632 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,158 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 513 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,020 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,271 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,021 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,346 08-07-2023, 06:12 AM
Last Post: mikeb
