looking to Run UBuntu 18.xx.x.xx on pine
hello guys !
I've been looking for a method to write a uboot compatible image of Ubuntu ,
trying (failing ) to follow this
installing other ARM64 distributions
Warning: Distributions not on this page may not even boot after you follow this section. In the best case, they will be barely usable. This is more for fun, or if you would like to port a new distribution to the PinePhone.
Note: This section uses megi's kernel releases, and not the official ones from PINE64. While it is possible to use the official (and in the future, mainline) kernel, megi provides binary releases, which makes it very easy.
If you would like to see specific commands for how to complete these steps, see https://github.com/nikhiljha/pp-fedora-sdsetup
(an example for Fedora) or https://xnux.eu/howtos/install-arch-linux-arm.html
(an example for Arch Linux).
Create a boot (from 4 MB to about 252 MB) and root (from 252 MB to the end of the card) filesystem on the SD card.
Format the boot partition with vfat, and the root partition with f2fs.
Extract the root filesystem from your distribution's ARM image into the root filesystem on the SD card. Do not copy the partition, copy the files (in archive mode: like rsync -ar).
Edit /etc/fstab to match your partitions.
Grab megi's kernel from https://xff.cz/kernels/
(you probably want 5.6 or later).
Follow the README instructions, which involves copying the kernel modules into the SD card rootfs and writing u-boot and the bootloader.
(https://wiki.pine64.org/index.php/PinePhone_Software_Releases
with no luck , have you succeded trying to write other images than posted on
I've seen that Rpi 3 and 4 uses similar Uboot stuff but no clear how I can create a boot and appropriate IMG for the pinephone
as you can see I am very new to this , hope you can share some
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 761 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  Jami on the Pine phone ? bcnaz 7 5,451 04-03-2022, 12:10 PM
Last Post: Fish
  First time pine phone user Matt73 3 2,377 03-10-2022, 02:04 AM
Last Post: Matt73
  Pine phone Battery life vs operating system bcnaz 19 20,884 08-27-2021, 09:35 PM
Last Post: bcnaz
  Pine Phone Desktop Mode or "Standard" Gnome Desktop on PinePhone? 4920441 4 4,864 05-11-2021, 02:42 AM
Last Post: wizmart
  Pine Phone 64 - Indicator Lights specific to distribution? Harry27 1 2,227 03-04-2021, 01:21 PM
Last Post: wibble
  Phone calls on Pinephone Ubuntu touch? Peter Gamma 16 18,670 09-08-2020, 01:42 AM
  How hard is it to port OS images designed for the Pine a64 LTS to the pinephone? coolguy129 0 1,732 09-06-2020, 10:58 PM
Last Post: coolguy129
  Ubuntu touch, volume GloriousCoffee 3 4,795 08-04-2020, 03:05 PM
Last Post: rocket2nfinity
  Wifi configuration for Pine phone suren21 10 12,142 04-25-2020, 01:14 AM
Last Post: suren21
