Printer driver lib32-glibc dependency
Hey,
i tried to install this driver for my printer on the Pinebook Pro ->(https://aur.archlinux.org/packages/brother-dcp195c).
It needs the lib32-glibc package as an dependency but this seems to be not available for arm.
So my question might be a bit naive ...but it might be worth asking:
Is there a way to build it manual and use another alternative package?
Thank you in advance for help!
It's because that package installs a binary for x86 which is what that libc dependency is for.
I did get my Brother printer working using a driverless setup from CUPS, maybe it's possible for your model, too.
Another option is qemu userspace emulation, but that's also not trivial.
Does dcp-195c have a network connection? If not, driverless/airprint is a little harder
There is a "shim" for ipp over usb, you likely have to compile
The debian wiki has 2-3 good pages on all that
Also, cups has to be airprint capable (>2.3),
and of course, the printer too (printers > 10 years old may not be capable)
The quick way to find out, is this printer capable of printing from ipad/iphone?
(because most support people are clueless)
(07-03-2020, 10:39 PM)wdt Wrote: Does  dcp-195c have a network connection? If not, driverless/airprint is a little harder
Thanks for the answers.
The printer has no Network connection at all. It is plugged into a PC, but if I have to rely on the PC beeing on it makes no sense for me.
That was my guess,, the printer too old
If a printer has no network capabilities, it makes no sense for
airprint to be in rom (printer's rom)
  Manjaro update: nerd-font-terminus dependency issue Vinay 3 1,237 05-10-2023, 04:51 AM
Last Post: Vinay
  Audio Driver on the pbp korreckj328 5 1,542 05-01-2023, 12:58 PM
Last Post: korreckj328
  Testing a broken Vulkan driver LivingLinux 0 828 09-26-2022, 05:08 AM
Last Post: LivingLinux
  Manjaro update: wxgtk dependency issue Vinay 5 2,369 09-09-2022, 12:03 PM
Last Post: Vinay
  Solution for issue with 'panfrost' module not initializing due to missing dependency cobratbq 0 1,521 12-02-2021, 05:26 PM
Last Post: cobratbq
  Migrating from glibc to musl on Gentoo pkubaj 6 5,111 07-24-2021, 05:00 PM
Last Post: pkubaj
  Xorg graphics driver? rdenthem 2 4,050 08-28-2020, 09:21 AM
Last Post: rdenthem
  Installing Brother printer drivers on Manjaro dhosh 4 5,523 02-24-2020, 09:47 AM
  Installing Printer perfusion 2 3,470 02-05-2020, 09:03 PM
