Mobian screen dims
(06-27-2020, 05:26 AM)a-wai Wrote: Ok thanks! When you have time, could you please read through https://gitlab.com/mobian1/issues/-/issues/3 and replicate the measurements other people did?
(basically, every in_proximity_* files, both with the stock and custom kernel mentioned in the thread)
This would be helpful in trying to understand what's going on here (no hurry, it won't be solved overnight anyway).
Okay will do thanks.
I have exactly the same issue with my BH PinePhone trying to run the latest Mobian.
The login screen works perfectly, but then it turns grey. I can then press the power button a couple of times and use the login screen again, which is correctly drawn on the screen, but then as soon as I unlock, it's a grey screen again.
I obviously haven't been able to setup a WiFi connection yet for it - does the USB connection allow for a SSH connection on a plain Mobian image? I cannot get to a point where I can install anything.
Any help would be greatly appreciated.
Have a look at this thread: https://forum.pine64.org/showthread.php?tid=9694
I replaced my screen recently and forgot to move the "divider" to the new one at first.
After swapping them the issue is gone.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,516 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Screen auto-rotation sensitivity mdk 0 215 12-26-2023, 06:08 AM
Last Post: mdk
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,718 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,690 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 581 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,541 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,799 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
  Screen stay black unless power key pressed short freelectro 0 602 06-24-2023, 01:55 PM
Last Post: freelectro
