No 5GHZ WiFi networks available
Just got my pinebook pro in the mail and have been loving it so far, but it appears that I'm unable to connect to any 5GHZ WiFi networks.
This is very disappointing for me given how slow the 2.4GHZ band is due to congestion in my area.
Was wondering if anyone else had encountered this or had tips for troubleshooting
(06-22-2020, 04:32 PM)mkrupczak Wrote: Hello,
Hi, I have exactly the same problem. The first boot connected to the 5Ghz network but after software update now only detects 2.4Ghz wireless routers.
The updated WiFi firmware causes problems with 5Ghz WiFi. You should downgrade to the one linked in this post: https://forum.pine64.org/showthread.php?...9#pid67119
Then follow the instructions on downgrading from the Manjaro Wiki: https://wiki.manjaro.org/index.php?title...s_manually
That cleared it up for me.
(06-24-2020, 04:43 PM)carlosqueso Wrote: The updated WiFi firmware causes problems with 5Ghz WiFi. You should downgrade to the one linked in this post: https://forum.pine64.org/showthread.php?...9#pid67119
Carlosqueso,
    The link you posted about downgrading the wifi firmware is broken, clicking it takes you to a page that says that thread doesn't exist.  The Manjaro page link works though.
I refuse to tiptoe through life, only to arrive safely at death.
Carlosqueso,
So I'm bad at copying and pasting....I fixed the link in the original post
This doesn't seem to effect all Pinebook Pros? I am keeping mine updated as usual and 5ghz wifi is working fine as far as I can tell.
Anyone got some further insights into this?
it works fine with lower 5Gchannels.
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 752 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 535 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,834 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 1,126 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 1,812 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 14,358 05-24-2021, 05:03 AM
Last Post: walterbe
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 13,053 05-23-2021, 04:35 AM
Last Post: Ralim
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,122 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 2,960 01-21-2021, 10:21 AM
Last Post: moonwalkers
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,769 01-17-2021, 01:50 PM
Last Post: BananaPekan
