Boot from USB on PinePhone
Has this been done?
Someone else mentioned the ANX7688.  If that's the USB chip then this page: https://www.analogix.com/en/products/con...es/anx7688  says it's "Simultaneous USB 3.1 Gen1 (5.0Gbps) and DisplayPort Alternate Mode".
I'm after what they did with the PI ( https://hackaday.com/2020/05/25/boot-your-pi-over-usb/ ) to put the boot loader on emmc, use the rest of the emmc for data, and have a 5Gbs USB 3.1 to SD reader with a really fast SD card and multiboot all of the possible OS's from one SD card which also holds a nice swap file that again is much faster than the built in SD.
Opinions?
I'd like something similar, in order to boot from and play with various operating system images.
Some Raspberry Pi models will attempt to boot from USB if no SD card is present. However, they don't provide any way to select among multiple devices. What I'd like is a command in the "base" operating system (e.g., on eMMC or the microSD card) that causes a reboot from a specified file path. Ideally, this could be on any available file system (eMMC, microSD, USB).
Not going to work.  While PinePhone has a USB-C port and the chip you mention can indeed drive DisplayPort out of the connector, the SoC is only capable of USB2 so you won't like the performance if you try running mass storage off of the USB port.
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 32 23,369 03-21-2024, 04:27 PM
Last Post: donchurch
Wink PINEPHONE not booting Touchwood 2 284 02-23-2024, 07:27 AM
Last Post: Touchwood
  Can't boot on SD anymore LeNouveau 1 244 02-12-2024, 01:05 PM
Last Post: LeNouveau
  Slack on PinePhone Adam Seline 5 5,159 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 22,970 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 1,718 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 100,008 11-17-2023, 08:37 AM
Last Post: Uturn
  Using Signal on PinePhone in mid-2023? dante404 45 11,773 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 820 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 1,845 10-24-2023, 08:57 AM
