Libertine / XMir not connecting to Mir
(07-01-2020, 11:46 AM)doniks Wrote:
(06-27-2020, 12:06 AM)Saliency Wrote:
(06-25-2020, 06:50 PM)Olllsondowlll Wrote:
(06-21-2020, 12:17 PM)Saliency Wrote: I used pmbootstrap to install phosh. Then after booting up my phone I did sudo apk add xeyes and then was able to launch xeyes. The xeyes showed up right away, and responded by looking where I was tapping around them.
I'm curious. Where was xeyes able to follow you. I'd assume only inside the xeyes window. I would expect that Wayland prohibits it to know where you point if your not pointing at itself
Yes you are right — xeyes only followed my touches within the xeyes window. It ignored all touches outside.
If I launch another app like Settings, I can switch back to xeyes and its little window floats above Settings.
Also — I cannot move/drag the xeyes window (no window manager?)
  Libertine? Zweitaktmotor 12 17,610 08-05-2020, 12:57 PM
Last Post: linmob
  Pinephone UBPorts not connecting to computer badisautumnum 14 18,924 07-22-2020, 01:25 PM
Last Post: natasha
